CIPC IPv6 Support
Does IP Communicator 8.6.3 support IPv6?
I have a client who is using MS Direct access VPN.  The remote access solution has been deployed using ipV6.  CUCM has been deployed on the corporate network using ipV4.  ipv6<>ipV4 translation is used between the two networks.   As there is no way of  specifying an IPv6 TFTP server address within the IPC client could it be done using DNS?, ie   Is there anyway of forcing the IPC client to use DNS instead of the static IP address for the TFTP address - something in the registry maybe?  The IPv6 DNS server would then resolve the TFTP name to a IPv6 address.  The IPv6<>IPv4 translator could then translate the v6 address to a real v4 TFTP address.
Steve
1 REPLY
My company uses DA and we
My company uses DA and we recently deployed CUCM 9.0.  As Steve described above, CIPC only communicates using IPv4.  DA will not translate IPv4 addresses and there's no option in the CIPC client to use DNS instead of the TFTP server IP addresses.  Has anyone found a workaround for this?
Thank You
Don
443
