Community Member
CIPC no audio but rings fine
CIPC on my Win 7 laptop will play the ringing tone when dialled but get no audio.
Any clues?
Rich
Everyone's tags (5)
Super Bronze
CIPC can have different devices assigned for ringer and general audio - so your speakers can ring, but then you listen on your headset for example. Check your audio settings.
Also when on a call, press the ? key twice on the CIPC display, you'll get stats and you should be able to see your RX counters. If you don't see them incrementing then you have something blocking the RTP stream -this might be a client/windows firewall, a VPN NAT issue, or a million other things.
IF rx is incrementing then you are receiving them OK, so try messing with the audio output settings or run the tuning wizard again.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi Aaron,
Its just in a lab so no VPN/NAT involved. I suspect its my laptop and will try suggestions and post back.
Cheers
Rich
Also, make sure that if you are using your wireless that you have your wireless nic's mac address entered in cucm and not your lan mac and vise versa. To get around that issue i usually enter cipc's into cucm by using a name so you dont have to worry about that.
Community Member
Sorted. Stupid Microsoft junk.
Control Panel>Hardware and Sound>Playback>'Set Default' to Speakers.
Cheers all.
Rich.
Super Bronze
Good to hear you have it resolved.
Please remember to rate useful responses and mark your question 'answered' if appropriate..
Aaron
1082
