CIPC phone
HI
I have a Soft phone installed which is registered to my CME . i wanted to know whether this will support Meet Me conferencing .
i suspect this will not work because meetme key( softkey ) is not reflecting in my soft phone when added this softphone to ephone template having meetme key..
Please suggest . Thanks in advance .
K.S.
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Super Bronze
CIPC phone
You need to configure ephone-template to enable meet-me softkey...
Use this link to configure correctly..
http://uc500.com/files/CME-4-1-HW-Conf-Tech-Tip.pdf
e.g
ephone-template 1
softkeys hold Join Newcall Resume Select
softkeys idle Cfwdall ConfList Dnd Join Newcall Pickup Redial RmLstC
softkeys seized Endcall Redial Meetme Cfwdall Pickup Enable MeetMe softkey in seized/offhook state
softkeys connected ConfList Confrn Endcall Hold Join Park RmLstC Select Trnsfer
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
CIPC phone
It should work, Check the configuration in the link below to get the meet me configuration under CME:
https://supportforums.cisco.com/thread/2151962?tstart=0
Amer
VIP Super Bronze
CIPC phone
e.g
ephone-template 1
CIPC phone
Yes this works now . Thanks
CIPC phone
hI guys,
i am new in the cisco world, i need to configure a cipc to be used over VPN connection. what is the parameters that i need to define in the cme so that the cipc will work no matter from what network interface i am using. i have registered a cipc in the internal network using the mac address of the lan and it worked but over vpn it is a different case. i have registered all possible mac addresses vpn, wireless, lan and stil not working.
please can you assisst.
VIP Super Bronze
Re: CIPC phone
I usually use my VPN adapter mac address. What is the problem you are experiencing? Does your CIPC not register?
You also need to ensure that your CME can route to the VPN adapter ip address
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
922
