Bronze
cipc ver 2-1-1 for Vista
Version cipc-Admin-ffr.2-1-1.zip for Vista and getting error
"could not find network adaptor need for registration"
I cannot find a way to get into "preference" to change network
adaptor so tried reinstalling and same problem
I also tried going into install folder under
C:\Program Files\Cisco Systems\Cisco IP Communicator
and cannot find any exe file to help me change the network preference.
1 REPLY
Hall of Fame Super Red
Re: cipc ver 2-1-1 for Vista
Hi Anthony,
It sounds like you may be hitting this bug;
CSCsi50272 Bug Details
VISTA: Launching IPC, standard user prompted to select Network interface
Symptom:
If non admin user (Vista Business and Vista Enterprise call it Standard User) launched communicator first time on Vista Enterprise or Vista Business, then he is asked
to select Network Interface to register with Cisco CM.
Conditions:
Deploying using the Windows installer in a locked-down environment
Workaround:
Admins need to provide the correct info before deploying.
End users can just select the appropriate device as per admins instructions.
Hope this helps!
Rob
128
