CIPC wont register
I have CIPC 8.6 installed on Win 7 laptop using Cisco VPN into the company.  I can not get it to register.  It just keeps saying configuring IP...
Help needed.
1 ACCEPTED SOLUTION
Hi.
Hi. Ensure that you are using "Use this device name" instead of using network interface on CIPC's network configuration On device name field should be present the one specified on CUCM HTH Regards Carlo
Please rate all helpful posts "The more you help the more you learn"
Have you already verified you
Have you already verified you can reach CUCM, and basic connectivity??
That your VPN has routing to CUCM??
java
if this helps, please rate
www.cisco.com/go/pdi
IT does download the CTL file
IT does download the CTL file from the CUCM but then nothing.......
Can you download the phone's
Can you download the phone's config file via a TFTP client on the same PC while connected to the VPN?
I dont know.  I dont have a
I dont know.  I dont have a TFTP client on my laptop.
Install one then?
Install one then?
Hi.
80
