CIPC2.1.3.0 over VPN to CIPC2.1.3.0 over VPN -no audio
Using
CIPC 2.1.3.0
VPN 5.0.02.0090
2821 Router
CIPC is working fine in all scenarios (e.g. CIPC over VPN to 7941) except:
CIPC over VPN to another CIPC over VPN call is connected but there is no audio in either direction.
Anybody have any ideas?
1 ACCEPTED SOLUTION
Re: CIPC2.1.3.0 over VPN to CIPC2.1.3.0 over VPN -no audio
Hi Sean.
This is probably not a Telephony issue at all, this is most likely a VPN problem. Your VPN device may not currently be allowing ip packets to flow between the two remote endpoints. I use a VPN 3005 concentrator and I had to explicitly allow this ability in my VPN configuration before any of my VPN endpoints could make any sort of direct connection between each other.
-Adam
Hi Sean.
-Adam
Hi Adam,
Ok, thanks, I'll take a look at that angle.
Sean
Hello Again Adam,
Thanks, that resolved the issue
Sean
Where, specifically, did you configure this on the concentrator?
140
