CIPT1 642 447 help
Can anybody help on the below:
I have few questions with strange or contradictory answers on the net, when I check the official documentations, the answers are not obvious. To save time, I give you these examples:
Question 1 Which 3 CUCM settings can be used to support IP phone services (choose 3)
A) Device defaults
B) Enterprsie parameters
C) IP phone service configuration window
D) Common phone profile
E) Service Parameters
F) Phone configuration window
Question 2 A dial peer is configured with an outgoing COR list. Which two conditions must be met for calls matching this outbound dial peer to be blocked? (Choose two.)
A)An incoming COR list must be configured on the matched inbound dial peer.
B)An incoming COR list must be configured on the matched outbound dial peer.
C)The outgoing COR list must be a superset of the incoming COR list.
D)The incoming COR list and the outgoing COR list must contain the same members.
E)The outgoing COR list must be a subset of the incoming COR list.
Question 3   When a new subscriber is added to a Cisco Unified Communications Manager cluster, how must the subscriber be configured so that is can receive database updates?
A) The subscriber uses the security password configured when the subscriber was configured.
This is also configured in the publisher and validated on the initial replication of the database.
B) The subscriber uses the subscriber security password configured in the publisher.
C) The subscriber uses the same security password configured in the publisher when it was created.
D) The subscriber uses the IDS security password.
Question 4 Which of these is used for call and directory lists that are enabled for native Presence in Cisco Unified Communications Manager?
A) Subscribe CSS and Presence groups
B) Presence groups and Phone Line CSS
C) Presence groups and Phone Device CSS
D) only Presence groups
E) Subscribe CSS only
Question 5 Which three of these are characteristics of a Cisco Unified Communications Manager software-based Media Termination Point? (Choose three.)
A) The codec and packetization of both call legs must be identical.
B) This Media Termination Point type does not require any DSP resources on the Cisco router.
C) DSP resources are required.
D) It can provide G.711 mu-law to G.711 a-law conversion and vice versa.
E) It can provide packetization conversion for a given codec (for example, if one call leg is using a 20-ms sample size, but the other call leg is using a 30-ms sample size).
F) This Media Termination Point type is typically used for RSVP agent configurations or Cisco Unified Border Element media flow-through configurations.
Thank you
  • IP Telephony
Everyone's tags (3)
489
