Cisco 1861E IOS 15.1(3)T CME 8.5
dcolarte
I am trying to enable the CME GUI on an 1861E but am having great difficulty.  I uploaded what I thought were the necessary files into flash but when I attempt to access the GUI I get a page that is missing items.
If someone could spell out the process more clearly that Cisco documentation on how to enable the GUI & which files need to be loaded into flash, it would be greatly appreciated.
Thanks in advance.
DC
9 Replies 9
ronpatel
Level 8
Level 8
Attach Configuration of CME please. Also let us know what broswer you are using.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Sorry for the late response. I did not receive a notice that anyone responded.  In any case, here is the Config:
Router>enable
Router#show run
Building configuration...
Current configuration : 2690 bytes
! Last configuration change at 22:17:14 pst Tue Mar 13 2012 by admin
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone pst -4 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
dot11 syslog
ip source-route
ip cef
ip dhcp pool VOICE
   network 192.168.100.0 255.255.255.0
   option 150 ip 192.168.100.1
   default-router 192.168.100.1
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
voice-card 0
license udi pid C1861E-SRST-C-F/K9 sn FTX160785RZ
username admin privilege 15 secret 5 $1$JrE1$4a.BJGAPS8kcHVqE3mle80
interface FastEthernet0/0
description $ETH-WAN$
ip address dhcp client-id FastEthernet0/0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
switchport access vlan 10
interface FastEthernet0/1/8
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
logging esm config
access-list 1 remark INSIDE_IF=Vlan10
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
mgcp profile default
telephony-service
max-conferences 4 gain -6
web admin system name admin secret 5 $1$f/jG$YCw36SDn2AsSyadA9xvqI/
dn-webedit
time-webedit
transfer-system full-consult
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
transport input all
ntp server 192.43.244.18
end
I am running IE 9
Thanks again,
DC
This is asked quite often. IE9 doesn't work with CME GUI. Use Firefox or older IE.
Hi Paolo,
Good to know....thank you.  Unfortunately though, it did not resolve the issue. I get the logon box, login & I am presented with the screenshot above & non of the hyperlinks work.
DC
Make sure you are using the right files.
Copy files to a directory, configure it with "ip http path".
I think that may very well be my issue. Which files would in fact be the "right files" for my version of IOS?  I copied the files within the CME 8.5.0 GUI folder to flash.  See image....
So you only have to configure it right.
You would have saved time by searching before asking.
You're losing me here, Paolo.  What you see above is what I had done prior to posting on this forum & it is NOT working.  So my question is, what am I missing?  I have followed Cisco's documentation for setup & the result is a CME GUI that does not work.  The logon box comes up, I enter the WebAdmin username & pw that I setup in CLI & all I get is a webpage that will not fully load.
So that being said, do you or anyone else have some insight to what I may be missing?
thank you,
DC
I think you have not read my post above.
