Cisco 2432-24FXS Calls won't ring FXS ports when placed in Huntgroup
I am having an issue getting calls to ring through on the FXS ports when using the "trunkgroup" command under the POTS dial-peers. Calls will ring through fine if I use the "port" command under the pots dial-peer. What I am trying to accomplish is getting a single number to hunt through 13 FXS ports in a round-robin fashion. With the below setup I am getting a SIP 404 not found message in the SIP debug info. I am not sure if I am missing something here or what the deal is. If the below information is not enough I would be happy to provide additional info. Any idea's why this configuration doesn't seam to work?
trunk group HuntGroup1
hunt-scheme round-robin both up
dial-peer voice 1 voip
translation-profile outgoing 7to11
destination-pattern .T
progress_ind setup enable 3
no modem passthrough
voice-class codec 1
session protocol sipv2
session target dns:XXXXXXXX
dtmf-relay rtp-nte
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 300 pots
trunkgroup HuntGroup1
description TEST NUMBER
destination-pattern XXXXXXXXXX
voice-port 2/0
trunk-group HuntGroup1
timeouts interdigit 3
description HuntGroup 1 Line 1
station-id number XXXXXXXXXX
caller-id enable
voice-port 2/1
description HuntGroup 1 Line 2
caller-id enable
voice-port 2/2
description HuntGroup 1 Line 3
caller-id enable
voice-port 2/3
description HuntGroup 1 Line 4
caller-id enable
voice-port 2/4
description HuntGroup 1 Line 5
caller-id enable
voice-port 2/5
description HuntGroup 1 Line 6
caller-id enable
voice-port 2/6
description HuntGroup 1 Line 7
caller-id enable
voice-port 2/7
description HuntGroup 1 Line 8
caller-id enable
voice-port 2/8
description HuntGroup 1 Line 9
caller-id enable
voice-port 2/9
description HuntGroup 1 Line 10
caller-id enable
voice-port 2/10
description HuntGroup 1 Line 11
caller-id enable
voice-port 2/11
description HuntGroup 1 Line 12
caller-id enable
voice-port 2/12
description HuntGroup 1 Line 13
caller-id enable
Message was edited by: Thomas Schmidt Added CCSIP Debug and Router Config.
Everyone's tags (3)
Re: Cisco 2432-24FXS Calls won't ring FXS ports when placed in H
Hi.
Can you please attach the complete config and a debug ccsip message?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Config and Sip Debug have been uploaded.
Tom
199
