cisco 2801 with VIC2-2FXS = no voice ports !
mathieu.ploton
<br />
<br />I just get a brand new cisco 2801 and a VIC2-2FXS that I install in the slot 0 (VIC only).
<br />
<br />I can see my card in the sh diag and sh ver but the voice ports never appear on the sh run. I can't type voice-port either...
<br />
<br />Router#sh ver
<br />Cisco IOS Software, 2801 Software (C2801-IPVOICE-M), Version 12.3(11)YZ2, RELEASE SOFTWARE (fc2)
<br />Technical Support: http://www.cisco.com/techsupport
<br />Copyright (c) 1986-2007 by Cisco Systems, Inc.
<br />Compiled Wed 08-Aug-07 23:47 by dchih
<br />
<br />ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
<br />
<br />Router uptime is 21 minutes
<br />System returned to ROM by power-on
<br />System image file is "flash:c2801-ipvoice-mz.123-11.YZ2.bin"
<br />
<br />Cisco 2801 (revision 7.0) with 115712K/15360K bytes of memory.
<br />Processor board ID FCZ124611SS
<br />2 FastEthernet interfaces
<br />2 Voice FXS interfaces
<br />DRAM configuration is 64 bits wide with parity disabled.
<br />191K bytes of NVRAM.
<br />62720K bytes of ATA CompactFlash (Read/Write)
<br />
<br />Configuration register is 0x2102
<br />
You will need PVDM2 in all ISR routers to turn up the voice ports. If no dsp's exist then you will not have that ability to configure them.
paolo bevilacqua
You have no PVDM2-xx modules in the box. These are the DSP and no use of voice ports can be done without.
Would I get the same problem using a cisco 2811 ?
