CISCO 2811 standalone fax solution
I would like to setup a fax using a router cisco2811-ccme/k9, to push fax
into email system.
I would like to get configuration support for this task. The interface is a two-port voice
card vic2-2fxs=. Also I would like to know if there are other options to deploy this fax configuration to send it direct into the printer, to ftp or to a file share direct from the router. Any feedback will be appreciated.
BelugaTech
1 REPLY
Hall of Fame Super Gold
Re: CISCO 2811 standalone fax solution
Hi, search "configuring t.37" on CCO. That way, router will send fax as email.
If you want more than that, you need fax software that interacts with the router.
117
