Community Member
Cisco 2821 CUBE with H.323 Trunk
Hi ,
I have a Nortel CS1000M box version 5.0.There is a Cisco 2821 CUBE.There is a H.323 Trunk between CUBE and the Nortel CS1000M and there is SIP Trunk between CUBE and the SONUS NGN gateway.
In this scenario if a call comes from SIP trunk and hit to CUBE and pass through the H.323 Trunk is there any dependency on SIP to H.323 Interoperability issue.Is the Call transfer will support in this scenario......
Please let me know.
Regds....
Yes it will work. Are you facing any issue in the setup ?
GP.
Community Member
Hi Gajanan,
Thanks for the reply.
I am facing problem with call disconnection when we take a call and transfer the same call to 3rd person.But i saw some documber where it says CUBE with Nortel will not support blind transfer.....Is that true...
Regds.....
hmm..could you pls explain the call transfer scenario by taking 3 user's example & clearly demarking them which Call controller they belong to ?
GP.
393
