Cisco 2821 gateway not register callmanager 5.0
aryandav_bali
My cisco gateway 2821 is not registoring with callmanager 5.0
i have put following configuration in cisco 2821 gateway
dial-peer voice 21 voip
destination-pattern .....
voice-class codec 1
session target ipv4:X.X.X.X
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
voice service voip
h323
Get integrate with gatekeeper
interface Loopback0
ip address X.X.X.X 255.255.255.255
ip pim sparse-dense-mode
h323-gateway voip interface
h323-gateway voip id hswan ipaddr X.X.X.X 1718 priority 10
h323-gateway voip h323-id gw_1
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr
X.X.X.X
and at callmanager end i have add cisco 2821 as H323 gateway,
But when i have check the status of VOIP gateway over CallManager, there Staus is not Unknown
If any one have any solution plz let me know
Arun Sharma
M--09988445070
allan.thomas
Level 8
Level 8
For your information, H323 Gateways do not register with CCM as they do with MGCP.
You can obviously debug h323 h225 to verify whether you see messages from CallManager, however it would be easier to configure the H323 gateway name in CCM with the IP address with which you binding h323.
Although the gateway status is always shown as unknown, the IP address should be shown if you configure the endpoint as above, this indicate that both are communicating.
Allan.
