Community Member
Cisco 2851 w/ CME 8.x & SIP Trunk via Vitelity
I have a Cisco 2851 loaded with DSPs and it has an internet connection to support the SIP trunk to Vitelity. Below are the appropriate sections of my config for this setup. I am running CME in both SCCP and SIP which is why i have some SIP bind to interfaces.
Here are the things i would like to get functioning...
- Incoming calls working properly... Currently i get a slow busy when I try to call my DID at Vitelity. Outgoing works correctly.
- Outgoing callerID setup correctly. How do i specify a static # and how do i specify 123456XXXX like CM works.
- Currently when i dial out i don't have to dial 9... 9 doesn't work to dial out, just regular dialing.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
  h450 h450-2 timeout T1 1000
  h450 h450-3 timeout T1 1000
  h225 display-ie ccm-compatible
modem passthrough nse codec g711ulaw
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 2
  call start fast
  telephony-service ccm-compatible
  ccm-compatible
dial-peer voice 9 voip
destination-pattern .T
session protocol sipv2
session target sip-server
session transport udp
incoming called-number 9T
voice-class codec 1
dtmf-relay rtp-nte
sip-ua
credentials username *** password 7 *** realm asterisk
authentication username *** password 7 *** realm asterisk
no remote-party-id
retry invite 2
retry register 2
registrar dns:sip32.vitelity.net expires 3600
sip-server dns:outbound.vitelity.net
host-registrar
telephony-service
moh-file-buffer 1024
authentication credential rtradm rtradm
max-ephones 100
max-dn 250
ip source-address 10.x.x.9 port 2000
timeouts interdigit 5
system message Corp Office
url services http://10.x.x.8/voiceview/common/login.do
url authentication http://10.x.x.9/CCMCIP/authenticate.asp
cnf-file location flash:
load 7937 apps37sccp.1-4-5-7.bin
load 7942 SCCP42.9-3-1SR2-1S.loads
load 7945 SCCP45.9-3-1SR2-1S.loads
load 7962 SCCP42.9-3-1SR2-1S.loads
load 7965 SCCP45.9-3-1SR2-1S.loads
keepalive 10 auxiliary 10
voicemail 6500
max-conferences 16 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.x.x.9
web admin system name rtradm password rtradm
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Dec 15 2013 19:26:37
VIP Super Bronze
Lets start by looking at the incoming call issues..
Please do a test cal and sned us
debug ccsip messages
debug voip ccapi inout
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Below is an output of an inbound call...
Dec 30 04:48:32.439: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:MYoutsideNumber@MYoutsideIP:56342 SIP/2.0
Via: SIP/2.0/UDP 66.241.99.90:5060;branch=z9hG4bK209f473e;rport
To:
Contact:
Call-ID: 5135dea77fee81556835ea5462f3e050@66.241.99.90
CSeq: 102 INVITE
User-Agent: packetrino
Max-Forwards: 70
Date: Mon, 30 Dec 2013 04:48:32 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 334
v=0
o=root 22208 22208 IN IP4 66.241.99.90
s=session
c=IN IP4 66.241.99.90
t=0 0
m=audio 17164 RTP/AVP 0 8 3 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Dec 30 04:48:32.451: //93/77FD6BB28038/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Dec 30 04:48:32.455: //93/77FD6BB28038/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 403 Forbidden
To: ;tag=3126AC-AD5
CSeq: 102 INVITE
Reason: Q.850;cause=21
Content-Length: 0
Dec 30 04:48:32.503: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:MYoutsideNumber@MYoutsideIP:56342 SIP/2.0
To: ;tag=3126AC-AD5
Contact:
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Dec 30 04:48:32.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip32.vitelity.net:5060 SIP/2.0
Via: SIP/2.0/UDP MYinsideIP:5060;branch=z9hG4bK82388
To: <>6001@sip32.vitelity.net>
Call-ID: 999E3908-705211E3-8004C118-6EF80127
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1388378912
CSeq: 18 REGISTER
Contact: <6001>
Expires:  3600
Supported: path
Content-Length: 0
Dec 30 04:48:33.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 30 Dec 2013 04:48:33 GMT
Max-Forwards: 70
Timestamp: 1388378913
CSeq: 18 REGISTER
Contact: <6001>
Expires:  3600
Supported: path
Content-Length: 0
Dec 30 04:48:34.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 30 Dec 2013 04:48:34 GMT
Max-Forwards: 70
Timestamp: 1388378914
CSeq: 18 REGISTER
Contact: <6001>
Expires:  3600
Supported: path
Content-Length: 0
Dec 30 04:48:34.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 66.241.99.90:5060;branch=z9hG4bK66b800c4;rport
To:
Contact:
Call-ID: 2ef384ac72250a9d48bb20235f947bc2@66.241.99.90
CSeq: 102 INVITE
Max-Forwards: 70
Supported: replaces
Content-Length: 334
v=0
s=session
t=0 0
m=audio 15832 RTP/AVP 0 8 3 18 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec 30 04:48:34.563: //95/793F13E4803D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
CSeq: 102 INVITE
Content-Length: 0
Sent:
To: ;tag=312EE4-2A1
CSeq: 102 INVITE
Content-Length: 0
Dec 30 04:48:34.615: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: ;tag=312EE4-2A1
Contact:
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Router#
you are receiving INVITE message from this ip: 66.241.99.90. have you configured this ip in cme to accept the sip connection?
//Suresh Please rate all the useful posts.
VIP Super Bronze
Like Suresh said, this looks like toll fraud prevention. You need to add the ips of your sip provider to your ip addres trusted list
voice service voip
ip address trusted list
ipv4 66.241.99.90 X.X.X.X where x.x.x.x = subnet mask of the ip
Community Member
I added the below to cover my basis since my SIP provider has an IP range and I am using DNS names instead of IPs for the connection. Still getting a slow busy when calling the outside number. From my SIP provider i get a message saying... "We received 'CONGESTION' when attempting to route the call to your server or device."  At the bottom is a new debug log of whats happening. Just a side note, i do have an ASA 5505 between the internet and my 28xx router.
voice service voip
  ipv4 66.241.96.0 255.255.240.0
  ipv4 66.241.99.90 255.255.255.255
Router#
Dec 30 15:43:29.562: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:MYsipTrunkNumber@MYexternalIP:54766 SIP/2.0
Via: SIP/2.0/UDP MYsipProvider:5060;branch=z9hG4bK1b517ef6;rport
To:
Contact:
Call-ID: 57a61ab24a7068834b38d68f4cd47a99@MYsipProvider
CSeq: 102 INVITE
Max-Forwards: 70
Date: Mon, 30 Dec 2013 15:43:29 GMT
Supported: replaces
Content-Length: 334
v=0
o=root 22208 22208 IN IP4 MYsipProvider
s=session
c=IN IP4 MYsipProvider
t=0 0
m=audio 19262 RTP/AVP 0 8 3 18 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec 30 15:43:29.566: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: ;tag=1F4309C-23DB
CSeq: 102 INVITE
Reason: Q.850;cause=100
Content-Length: 0
Dec 30 15:43:29.598: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:MYsipTrunkNumber@MYexternalIP:54766 SIP/2.0
Contact:
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Router#
When the gateway processes an initial INVITE, a determination is made  whether or not the host portion is in IPv4 format or a domain name.
If  the host portion is an IP address, its IP address is compared with the  interfaces on the gateway.
If a match is found, the INVITE is processed  as normal.
If there is not a match, the gateway sends a 400 Bad Request –  `Invalid IP Address' message
could you please verify 'MYexternalIP' is configured? are you doing any NAT?
Community Member
MYexternalIP is my ISPs IP assigned to the WAN interface of my ASA5505. The 28xx sits on the LAN side of my ASA on a 10.x.x.99 IP. The ASA is doing NAT between the outside and inside.  Does that answer the question? On my SIP providers side there is an option to enable NAT and that is currently turned on and believe it gets set when the box registers itself.
Community Member
Did the above make sense to anyone? If anyone is availible over the weekend i'd really like to resolve these issues. I'd be willing to compensate someone for their time, just PM me or reply.
VIP Super Bronze
From the logs, the external IP was not natted to the internal IP of your gateway. The ASA sent the packet as it is, hence the gateway is rejecting the call as Suresh already mentioned. You need to ensure that the externalIP is Natted to gateway's IP before the INVITE is sent to it..
Community Member
So i'm not quite following this... I have my ASA 5505 between the Internet and Inside doing nat from Public IP -> Internal IP range. I have a single static IP on the outside, which the ASA is using. Other computers on my Internet Vlan get to the internet just fine with the nat in place for 10.0.0.x to translated to my ASA's outside IP. Do I need to setup NAT on my Cisco 2811 Router thats doing SIP to translate its internet IP to the external IP? If this is the case will that affect any Lan traffic between the router and the phones? or am i completely missing something?
2602
