Community Member
Cisco 2901 register with CUCM 7.0.1
Hi all,
I have a problem when I try to register my Cisco 2901 in CUCM 7.0.1, because in the CUCM doesn't appear the option to select the Cisco 2901, only cisco 2801.
Is it possible to register c2901 as c2801?
Thanks in advance.
Best Regards.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Cisco 2901 register with CUCM 7.0.1
Hi there,
Support for the 2900's was not added until CUCM 7.1(3). Sadly, you won't be able to configure
it as a 2801 either
Cisco 2901, 2911, 2921, and 2951
Interface Part Numbers
Onboard PVDM2 and PVDM3 DSPs
TDM Protocol or
Feature
Conferencing and transcoding
Minimum Cisco
IOS Software
Release
15.0.1M
Minimum Cisco
Unified
Communications
Manager Release
6.1.5, 7.1.3 or 8.0
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Cheers!
Rob
Hi there,
it as a 2801 either
TDM Protocol or
Feature
Minimum Cisco
IOS Software
Release
15.0.1M
Minimum Cisco
Unified
Communications
Manager Release
6.1.5, 7.1.3 or 8.0
Cheers!
Rob
Community Member
Many thanks for the information.
Best Regards
319
