Cisco 2901 Router - CME
We have a Cisco 2901 Router with CME.
When dialing out, the destination phone does not see our name. They only see our number.
Our telco mentions the following:
"There is a configuration line on the Cisco gateway that is required. Customer has to make sure it is set for facility ie, by default Cisco is set up for display ie."
Here is the serial config.
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn supp-service name calling
isdn sending-complete
isdn outgoing ie facility
no isdn outgoing display-ie
trunk-group ALL_T1E1
no cdp enable
Any ideas?
Thanks.
Re: Cisco 2901 Router - CME
You should be all set as long as you have :
try doing a debug isdn q931 and see if you have the facility message with caller id similar to:
ov 17 15:54:48.821: ISDN Se1/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00BF
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Facility i = 0x9F8B0100A112020109020100800A4252322050686F6E6531
                Protocol Profile =  Networking Extensions
                0xA112020109020100800A4252322050686F6E6531
                Component = Invoke component
                        Invoke Id = 9
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = JOHN DOE
If not try changing the switch type to ni2c
Actually, I managed to figure it out.
Under my dial-peer voice pots, I had them set to "clid strip name".
I went into each dial-peer voice pots and ran a "no clid strip name" on them.
After completing this, the names began to display. But at this point, its the name associated with the phone. So, I also had to go into the CM's web interface and change the "Name" field under extensions.
Thanks for the help!
Phil...
769
