CISCO 2901 VOICE / VIC2-2FXO / IN/OUTBOUND CALLING TO SIP SERVER
I have been working on my config and made some really good progress.  Inbound calling from PSTN to IP is working well.  However I cant seem to lock down Outbound calling from IP to PSTN.  My goal is for calls outbound from SIP to PSTN to match on one of the two voip dial-peers and be send out the FXO_PORTS trunk group. The TO: header should be used less the first three digits.
Please see the log below and attached running config:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7406: *Feb 11 21:24:51.291: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/Handl
eUdpIPv4So
cketReads:
Msg enqueued for SPI with IP addr: [172.16.10.97]:5060
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7407: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/ccsip
_process_s
ipspi_queu
e_event: ccsip_spi_get_msg_type returned: 2 for event 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7408: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Transport/
sipTranspo
rtProcessN
WNewConnMs
g: context=0x0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7409: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Msg/ccsipD
isplayMsg:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7410: Received:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7411:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7412: INVITE sip:0012742328@172.16.10.1
00;transpo
rt=udp SIP/2.0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7413: From: <sip:8508@172.16.10.97>;tag=
a00ed10-61
0a10ac-13c
4-50022-17
745-2deb45
07-17745
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7414: To: <sip:0012742328@172.16.10.1
00>;transpo
rt=udp
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7415: Call-ID: a0156c0-610a10ac-13c4-5002
2-17745-35
1ba2d9-177
45
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7416: CSeq: 1 INVITE
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7417: Via: SIP/2.0/UDP 172.16.10.97:5060;branch=z
9hG4bK-177
45-5b9e5c2
-781c54d
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7418: Max-Forwards: 70
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7419: Supported: replaces
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7420: Contact: <sip:SPODSR01@172.16.10.97>
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7421: Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, REFER, SUBSCRIBE, NOTIFY
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7422: Allow-Events: refer,confere
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7423: nce
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7424: User-Agent: XXXXXXXXXXXXXXXXXXXXX
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7425: P-Asserted-Identity: "" <tel:2742328>
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7427: Content-Length: 231
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7428:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7429: v=0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7430: o=Intel_IPCCLib 167859904 167859905 IN IP4 172.16.10.97
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7431: s=Dialogic_SIP_CCLLIB
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7432: i=session information
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7433: c=IN IP4 172.16.10.97
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7434: t=0 0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7435: m=audio 49154 RTP/AVP 0 101
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7436: a=rtpmap:101 telephone-event/8000
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7437: a=fmtp:101 0-15
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7438: a=ptime:20
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7439:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7440: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/ccsip
_new_msg_p
reprocesso
r: Checking Invite Dialog
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7441: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
IAddContex
tToTable: Added context(0x314697E8) with key=[23] to table
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7442: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Transport/
sipSPIUpda
teResponse
Info: Dialog Transaction Address 172.16.10.97,Port 5060, Transport 1, SentBy Port 5060
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7443: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
State/sipS
PIChangeSt
ate: 0x314697E8 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7444: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Transport/
sipSPIUpda
teResponse
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7445: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
ISetDateHe
ader: Converting TimeZone NewYork to SIP default timezone = GMT
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7446: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Transport/
sipSPIUpda
teResponse
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7447: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IUpdateIde
ntity: SIP->PSTN: Setting Calling Name to
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7448: *Feb 11 21:24:51.295: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
IGetConten
tGTD: No GTD found in inbound container
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7449: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IUaddCcbTo
UASReqTabl
e: ****Adding to UAS Request table.
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7450: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IUaddCcbTo
Table: Added to table. ccb=0x314697E8 key=a0156c0-610a10ac-13c4-
50022-1774
5-351ba2d9
-177450012
742328
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7451: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IMatchSrcI
pGroup: Match not found on carrier id
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7452: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IMatchSrcI
pGroup: Match not found on Incoming called number: 0012742328
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7453: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IMatchSrcI
pGroup: Match not found on destination pattern: 2742328
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7454: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/ccsip
UpdateInco
mingCallPa
rams: ccCallInfo: Calling name , number 2742328, Calling oct3 0x00, oct_3a 0x81, Called number 0012742328
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7455: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetShrlPe
er: Try match incoming dialpeer for Calling number: : 2742328
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7456: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetFromCa
lledPartyI
d: P-Called-Party-ID header not found
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7457: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetPeerBy
CalledPart
yId: P-Called-Party-ID not found or parse error
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7458: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: No match found for P-Called-Party-ID
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7459: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Peer tag 100 matched for incoming call
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7460: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Precondition tag absent in Require/Supported header
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7461: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: This call is being treated for E8508
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7462: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7463: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Not using Voice Class Codec
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7464: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Checking Video Type Rate=-1 video_codec_allowed=1F
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7465: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Media/sipS
PICopyStun
ConfigFrom
PeerToCCB:
Firewall traversal is not enabled
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7466: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: xcoder high-density disabled
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7467: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Flow Mode set to FLOW_THROUGH
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7468: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetCallCo
nfig: Media forking disabled
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7469: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IContinueN
ewMsgInvit
e: Calling name , number 2742328, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 0012742328, oct3 0x00
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7470: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IContinueN
ewMsgInvit
e: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7471: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IValidateR
equestUri:
Not Enabled
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7472: *Feb 11 21:24:51.295: //-1/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IRscmsmAva
il: Value returned by check is = 0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7473: *Feb 11 21:24:51.295: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_IsS
DPPassthru
Enabled:  - 0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7474: *Feb 11 21:24:51.295: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_Get
HdrPassthr
uCfg: Hdr passthrough config:1 tag:0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7475: *Feb 11 21:24:51.295: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IProcessHi
storyInfoH
eader: No HI headers recvd from app container
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7476: *Feb 11 21:24:51.295: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IProcessDi
versionHea
der: No diversion headers recvd from app container
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7477: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IProcessRe
placesHead
er: No replaces hdr found
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7478: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoMediaNe
gotiation:
Number of m-lines = 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7479: SIP: (28) Attribute mid, level 1 instance 1 not found.
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7480: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Media/sipS
PISetMedia
SrcAddr: Media src addr for stream 1 = 172.16.10.100
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7481: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoAudioNe
gotiation:
Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7482: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoPtimeNe
gotiation:
One ptime attribute found - value:20
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7483: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/conve
rt_ptime_t
o_codec_by
tes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7484: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/conve
rt_codec_b
ytes_to_pt
ime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7485: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Media/sipS
PIDoPtimeN
egotiation
: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7486: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoDTMFRel
ayNegotiat
ion: m-line index 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7487: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
ICheckDynP
ayloadUse:
Dynamic payload(101) could not be reserved.
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7488: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoDTMFRel
ayNegotiat
ion: RTP-NTE DTMF relay option
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7489: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IDoDTMFRel
ayNegotiat
ion: Case of partial named event(NE) match in fmtp list of events.
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7490: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sip_s
dp_get_mod
em_relay_c
ap_params:
NSE payload from X-cap = 0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7491: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sip_s
elect_mode
m_relay_pa
rams: X-tmr not present in SDP. Disable modem relay
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7492: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IGetSDPDir
ectionAttr
ibute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7502: <009>Delayed Media          : No
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7503: <009>Bridge Done            : No
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7504: <009>New Media              : No
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7505: <009>DSP DNLD Reqd          : No
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7506:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7507: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/resol
ve_media_i
p_address_
to_bind: Media already bound, use existing source_media_ip_addr
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7508: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Media/sipS
PISetMedia
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7509: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_rep
ort_media_
to_peer:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7510:  callId 28 peer 0 flags 0x201 state STATE_IDLE
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7511: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7512: CallID 28, sdp 0x294E0F88 channels 0x3146AAA8
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7513: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/copy_
channels:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7514:  callId 28 size 0 ptr 0x2931E65C)
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7515: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7516: Hndl ptype 0 mline 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7517: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
: Selecting codec g711ulaw
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7518: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/codec
_found:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7519: Codec to be matched: 5
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7520: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
: ADD AUDIO CODEC 5
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7521:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7522: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/conve
rt_codec_b
ytes_to_pt
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7523: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
: Media negotiation done: stream->negotiated_ptime=20
,stream->ne
gotiated_c
odec_bytes
=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7524: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Error/sipS
PI_ipip_co
py_sdp_to_
channelInf
o:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7525: failed to update call entry
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7526: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7527: Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 172.16.10.97:49154
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7528: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7529: Hndl ptype 101 mline 1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7530: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
: setting ipip_caps DTMF to RFC2833: callid = 28, dtmf = 6
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7531: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInf
o[channel_
ndx].codec
= 5
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7532:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7533: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_cop
y_sdp_to_c
hannelInfo
o[channel_
ndx].codec
= -1
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7534:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7535: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_rep
ort_media_
to_peer:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7536:  callId 28 flags 0x100 state STATE_IDLE
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7537: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_rep
ort_media_
to_peer:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7538: Report initial call media
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7539: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_rep
ort_media_
to_peer: ccb->flags 0xC, ccb->pld.flags_ipip 0x201
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7540:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7541: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/copy_
channels:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7542:  callId 28 size 240 ptr 0x2919EED4)
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7543: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_rep
ort_media_
to_peer:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7544: CCSIP: Unable to report channel ind
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7547: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Media/sipS
PIUpdCallW
ithSdpInfo
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7548: <009>  Stream type            : voice+dtmf
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7575: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
ICanSetFal
lbackFlag:
Local Fallback is not active
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7593: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_sto
re_channel
_info: dtmf negotiation done, storing negotiated dtmf = 6,
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7594: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IShrlCall:
Check peer: 100 for Shared-Line call, callid: 28
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7595: *Feb 11 21:24:51.299: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/ccsip
_set_beare
r_capabili
ty:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7596:    Bearer Capability: Speech (0x00)
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7597: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
IGetConten
tQSIG: No QSIG Body found in inbound container
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7598: *Feb 11 21:24:51.299: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
IGetConten
tQ931: No RawMsg Body found in inbound container
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7609: *Feb 11 21:24:51.303: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IProcessCo
ntactInfo:
Previous Hop 172.16.10.97:5060
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7642:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7643: SIP/2.0 404 Not Found
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7644: Via: SIP/2.0/UDP 172.16.10.97:5060;branch=z
9hG4bK-177
45-5b9e5c2
-781c54d
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7657: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/ccsip
_process_s
ipspi_queu
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7658: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Transport/
sipTranspo
rtProcessN
WNewConnMs
g: context=0x0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7659: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Msg/ccsipD
isplayMsg:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7660: Received:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7661:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7662: ACK sip:0012742328@172.16.10.1
00 SIP/2.0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7663: From: <sip:8508@172.16.10.97>;tag=
a00ed10-61
0a10ac-13c
4-50022-17
745-2deb45
07-17745
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7664: To: <sip:0012742328@172.16.10.1
00>;tag=B14
5D8-7D3;tr
ansport=ud
p
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7671: Content-Length: 0
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7672:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7673:
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7674: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/ccsip
_new_msg_p
reprocesso
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7699: Negotiated Codec Bytes   : 160
2010-02-11 16:24:56      Local7.Debug      172.16.10.100      7700: Nego. Codec payload      : 0 (tx), 0 (rx)
2010-02-11 16:24:57      Local7.Debug      172.16.10.100      7721: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
ISipSdpFre
e:
2010-02-11 16:24:57      Local7.Debug      172.16.10.100      7722: *Feb 11 21:24:51.311: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
I_ipip_fre
e_codec_pr
ofile: Codec Profiles Freed
2010-02-11 16:24:57      Local7.Debug      172.16.10.100      7723: *Feb 11 21:24:51.311: //28/B934DE04-168A-11DF-80
66-80B7007
4B3A9/SIP/
Info/sipSP
IUfreeOneC
CB: Freeing ccb 314697E8
2010-02-11 16:24:57      Local7.Debug      172.16.10.100      7724: *Feb 11 21:24:51.311: //-1/xxxxxxxx-xxxx-xxxx-xx
xx-xxxxxxx
xxxxx/SIP/
Info/sipSP
IGetContex
tFromTable
: NO context for key[23]
2010-02-11 16:26:50      Local7.Notice      172.16.10.100      7725: *Feb 11 21:26:44.287: %SYS-5-CONFIG_I: Configured from console by admin on console
2010-02-11 16:34:46      Local7.Debug      172.16.10.100      7726: *Feb 11 21:34:40.639: CEF-HWIDB: EDSP0 LES switching vector set to Null
2010-02-11 16:34:46      Local7.Debug      172.16.10.100      7727: *Feb 11 21:34:40.639: CEF-HWIDB: EDSP0 LES switching vector set to CEF switching
2010-02-11 16:34:47      Local7.Notice      172.16.10.100      7728: *Feb 11 21:34:41.195: %SYS-5-CONFIG_I: Configured from http by admin on 172.16.10.1
2010-02-11 16:34:47      Local7.Notice      172.16.10.100      7729: *Feb 11 21:34:41.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
Everyone's tags (2)
1365
