Cisco 2911 CCME SIP trunk Configuration No-Codec
Hello all, I've trouble to make connections with my SIP operator. I have Cisco 2911 router. I can to register and when I check registration status show command shows that my router is registered but I can't make any connection I always have wait signal. I thought it is SIP operator problem but with the different SIP operator I have the same problem - when I make connection i have information no Codec - I don't know how to fix it. Please help.
When I chceck call status during the call using command sh sip-ua calls called-number 800900900 I've return:
while connection time I've chear waiting signal
Total SIP call legs:29, User Agent Client:1, User Agent Server:28
SIP UAC CALL INFO
Call 1
SIP Call ID                : 2611C8FE-BD5311E1-B982BB06-1C59C87F@64.44.212.11
  State of the call      : STATE_RECD_PROCEEDING (4)
  Substate of the call    : SUBSTATE_NONE (0)
  Calling Number          : 56
  Called Number          : 800900900
  Bit Flags              : 0xC00018 0x10800100 0x4280
  CC Call ID              : 74113
  Source IP Address (Sig ): 64.44.212.11
  Destn SIP Req Addr:Port : [79.133.193.90]:5060
  Destn SIP Resp Addr:Port: [79.133.193.90]:5060
  Destination Name        : sip.extravoip.pl
  Number of Media Streams : 1
  Number of Active Streams: 1
  RTP Fork Object        : 0x0
  Media Mode              : flow-through
  Media Stream 1
    State of the stream      : STREAM_ACTIVE
    Stream Call ID          : 74113
    Stream Type              : voice+dtmf (1)
    Stream Media Addr Type  : 1
    Negotiated Codec        : No Codec    (0 bytes)
    Codec Payload Type      : 255 (None)
    Negotiated Dtmf-relay    : inband-voice
    Dtmf-relay Payload Type  : 0
    QoS ID                  : -1
    Local QoS Strength      : BestEffort
    Negotiated QoS Strength  : BestEffort
    Negotiated QoS Direction : None
    Local QoS Status        : None
    Media Source IP Addr:Port: [64.44.212.11]:16476
At the another operator i've identical problem- No Codec
dial-peer command section
dial-peer voice 2 voip
description VOIP outbound
translation-profile outgoing OUT
destination-pattern 0[1-9]........
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
But I tried with that
Code:
voice-class codec 1
dtmf-relay rtp-nte
where voice class was: (I checked recommended codec settings at the operator website)
Code:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
SIP-UA configuration section
Code:
sip-ua
credentials username extravoip_XXXXXX password 7 XXXXXXXXXXXXXXXXXXXX realm ipv4:79.133.193.90
authentication username extravoip_XXXXXX password 7 XXXXXXXXXXXXXXXXXXXX
registrar ipv4:79.133.193.90 expires 900 auth-realm extravoip_XXXXXXXX
sip-server ipv4:79.133.193.90
I'VE NO IDEA WHY IT ISN'T WORKING, PLEASE HELP
debug output during the call
Code:
debug ccsip error
Code:
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
MF: Unable to read data from TD Container..
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
SIP: (75967) Group (a= group line) attribute, level 65535 instance 1 not found.
Jun 24 17:18:00.621: //75967/60CCAC2780C1/SIP/Error/sipSPILocateInviteDialogCCB:
Could not find ccb for response
Jun 24 17:18:01.481: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIFindBranchEntry:
invalid ccb, bName or branch list for sipSPIFindBranchEntry
Jun 24 17:18:01.581: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Orig Container is NULL...should have value
Jun 24 17:18:02.081: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:03.085: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:05.089: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:12.945: //75969/699BE87E80C7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.945: //75969/699BE87E80C7/SIP/Error/sipSPIUpdateCallInfo:
input argument error
Jun 24 17:18:12.949: //75969/699BE87E80C7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.949: //75969/699BE87E80C7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75975/699DBD8E80CD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75979/699EF5DE80D1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75989/69A2033E80DB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Comel-Cisco#
Jun 24 17:18:33.585: //75967/60CCAC2780C1/SIP/Error/sippmh_cmp_tags:
Parse Error in ccb From header
Jun 24 17:18:33.585: //75967/60CCAC2780C1/SIP/Error/sipSPICheckFromToRequest:
Failed FROM/TO Request check - IGNORE IF HAIRPIN CALL
                old_from:      "Krzysztof Przykładowy" <sip:56@79.133.193.90>;tag=9A65B64-B75
                old_to: <sip:800900900@79.133.193.90>
                new_from:      <sip:800900900@79.133.193.90>;tag=b783bbdaaa8a9a5852f95b0734870e25
                new_to: "Krzysztof Przykładowy" <sip:extravoip_138463@79.133.193.90>;tag=9A65B64-B75
Jun 24 17:18:33.585: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg:
Invalid method for (STATE_IDLE): BYE
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
********************************* Comel - Tomasz Hinz
  • IP Telephony
VIP Super Bronze
Can you send your sh run and send a debug ccsip messages. Please send the calling and called number
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
I have the same errors,
I have the same errors, exactly as yours , the Preview Mode works fine cause the calls go through the phone , but with others modes , nothing happens . the sip dialer doesn't send any Invite request .
I have the same problem as
I have the same problem as well. Did you get solved?
I also have the same problem and all my dial peers are using codec class 1. The codec class is defined accordingly.
6557
