Cisco 2911 Configuration- Caller ID Enable
Dear Sir,
I want to configure a caller ID feature of my Cisco Telephone.
I have Cisco 7945 and Cisco 9951 with camera.
I've already check our caller ID service in Telco and verified its active on my four lines and I do double check by putting the analog phone in each line and the number appears.
Here's my current configuration:
voice-port 0/0/1
cptone BR
connection plar opx 779
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
Please help. Thanks a lot
1 ACCEPTED SOLUTION
Hello Michael,
Let's try with the basics:
voice-port 0/0/1
no cptone BR
caller-id enable
no caller-id alerting line-reversal
no caller-id alerting dsp-pre-allocate
caller-id alerting ring 4
sh
no sh
Since you have a pretty new IOS 15.1(4)M3, you may want to try above commands. If CLID work, then you can reconfigure the CP Tone.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Micheal.
Which IOS version are you running on 2911?
Regards..
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Dear Sir,
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
VIP Super Bronze
Michael,
You need to check when the caller Id appears when you plug the analogue phone in. Is it after the first ring, second ring etc..please refer to the thread below for resolution to a similar issue
https://supportforums.cisco.com/thread/2237008?tstart=0
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Dear Sir,
For analog phone its appearing the ID.
The caller ID not appearing when I connect the Cisco Phone.
voice-port 0/0/1
cptone BR
caller-id enable
Thank you,
VIP Super Bronze
Did you try the suggestions in the thread I referred to above...?
Dear Sir,
What configuration i'm going to add to my existing Structure?
Thanks.
Hello Michael,
voice-port 0/0/1
no cptone BR
caller-id enable
sh
no sh
Jorge Armijo
287
