Cisco 2911 PRI dropping calls! Help!
I have a customer running CUCM 8.0 with 2 x 2911 routers on 15.0(1)M4 IOS. with 2 pcs PVDM3-32 and 1 VWIC2-2MFT-T1/E1.
On one of the ports they are running QSIG PRI againt a Ericsson MD110 and the other port is connected directly to a PRI 30 channel from a operator i Norway.
We are now getting drops on both these interfaces at the same time 2-5 times a day. When I look at the routers I see this error message:
%DSPRM-3-DSPALARM: Received alarm indication from dsp (0/1). Resetting the DSP.
According to Cisco this is a known problem on these routers with this IOS and their recommandations is to raise the
ecan-cancel coverage to 128. When I go to do this via the CCMadmin web on the endpoints I am not allowed to raise it to more then 64ms........When I force it to 128 directly on the router it doesn't show when I run Show running config but in the Show voice port 0/0/0:15 it says it is set to 128.
What is the correct thing here? Do I really need the EC-MFT-64 to get this thing to work or is it a fault that can be fixed with a IOS upgrade on the routers?
Hope there is someone out there that can help me in this case.
1 ACCEPTED SOLUTION
Green
This is what the bug you are hitting says
CSCtj71414 Bug Details
DSP crash in ecan when max tail delay configured is 32ms
Symptom:
PVDM3 DSP in ISR-G2 routers may crash. "show log" output of the router can be used to identify the crash :
Conditions:
When maximum ECAN tail length is configured to a value less than 80 ms.
Workaround:
Use default ECAN coverage value of 128ms.
Example :
voice-port 1/0:23
ecan-cancel coverage 128
It also says that it was updated 3 days ago
Fixed-In Fixed-in
15.1(3.22)T
I can not see this relaese in downlods I can only assume they mean
the latest IOS 15.1.3T3
Alex
Regards, Alex. Please rate useful posts.
Green
Symptom:
Conditions:
Workaround:
Example :
voice-port 1/0:23
Fixed-In Fixed-in
15.1(3.22)T
Alex
Yes that is the bug.......I see the latest IOS for the 2911 is the15.2(2)T. Can I not use this?
Green
Yes I would always use the latest IOS.
If you end up raising a TAC they like you to have the latest version installed.
Alex
Thanks Alex. I will perform the upgrade and see how it goes. So you don't think I have to buy the EC-MFT-64 to get this thing to work?
891
