Cisco 2911 QOS for VOIP - Unexpected Profile - NAT Issues - RTSP
Group,
Have some issues to run by you to get the experts opinion. Let's start with the setup:
HQ
2911 Router
SF300P Switches with QOS in basic mode, Voice VLAN 1
SPA504 IP Phone(s)
DC <-- Asterisk PBX located here with other SPA504 phones
Whats happening:
Some HQ users are complaining since I swapped the firewall from a SA540 to 2911 about phone to phone transfers in the HQ, not being able to hear, outside calls to HQ are hard to hear or one-way streams, calls from HQ to DC sometimes are one way audio streams, if you call back a couple of times you can finally establish a 2 way call, and its intermittent.
What I have been able to diagnose:
I have set QOS on the switch in basic mode and can verify that by running the queue 4 stats they climbing for queue 4 correctly on the unlink port from the switch to the firewall. However on the firewall when I monitor the QOS on the inside to outside interface I don't see any movement on the Signaling or Voice streams, I do see the CCP_Routing, CCP_Management, and CCP_Transactional climbing as we get phone calls.
I can verify that on the firewall the QOS policy for VOIP is set to EF and to AF31 respectively and seems to be correct, on the phones I can verify the policy is set to COS 3 & 5 respectively. 5/DSCP46/0xB8 3/DSCP26/0x68. Wireshark shows data flowing into the firewall has the correct DSCP set to 0xB8.
I have turned off SIP ALG on the 2911. Didn't seem to help. NAT is being handled by the phones, not Asterisk.
I have verified the RTP range and it doesn't seem the calls are out of range.
I have done a Wireshark trace at the DC end and can verify that when users at the DC are saying they can't hear the other party that at the PBX both RTSP stream exist.
Any feedback would be greatly appreciated. I have attached some profiles from the QOS and the QOS settings and the config is below. If you need further information please let me know and I will post it back.
Thanks experts!! Your insight and input are always valuable a rookie on these 2911's!
Building configuration...
Current configuration : 11240 bytes
! Last configuration change at 12:22:54 NewYork Thu Dec 26 2013 by cisco
! NVRAM config last updated at 11:10:28 NewYork Thu Dec 26 2013 by cisco
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname pl-gw1-paf-router1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 52000
enable secret 5 <EDITED>
enable password 7 <EDITED>
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone NewYork -5 0
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip bootp server
ip domain name <EDITED>
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip name-server 8.8.4.4
ip name-server 8.8.8.8
no ipv6 cef
crypto pki trustpoint TP-self-signed-1476751880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1476751880
revocation-check none
rsakeypair TP-self-signed-1476751880
crypto pki certificate chain TP-self-signed-1476751880
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343736 37353138 3830301E 170D3133 31313235 31373234
  31325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34373637
  35313838 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B70E D68704F7 1DC5B4C1 6DFF6421 41224111 E3BA9B0F 91C01E8E E9B61469
  8722444D C2347B5E EB063258 C4F61C0F E17E5B51 6A63D7FC B93FA1BD A58CC717
  D64DA408 56325935 C0F5D80C 5A1048AA 6DA0FF36 91A140A4 F9CDE135 955BF3E5
  67065FD6 947CA3BB 954FA23B 547F7C6D DE6DC530 259F2503 6E72581A 68F53F80
  74D70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 143012D1 A2989973 8A811A4E 124912E3 7CE0F9AC 41301D06
  03551D0E 04160414 3012D1A2 9899738A 811A4E12 4912E37C E0F9AC41 300D0609
  2A864886 F70D0101 05050003 8181005A ED92B7D5 9F05C89A FCC402E0 A71B2646
  DF3558B1 ABC98AD0 10E5895F 4C31590E 413F8598 371C20FF 80015DA1 950E37B6
  A33D3F94 C1680EF3 209B7F1D 4ABB3368 2028466F CB1BEE42 34F1C902 9F956F3E
  1238886E D4A9C4C3 7C9EFE6F D30B06C9 FC06DFAA 089622FE 1C171FEA 5D495E9A
  06053BF3 9CF06146 360285E7 1E8DAF
            quit
license udi pid CISCO2911/K9 sn FGL172810VH
license boot module c2900 technology-package securityk9
object-group service Asterisk
description Asterisk VOIP
udp source eq 5060
udp source range 16384 16842
username cisco privilege 15 secret 4 <EDITED>
username blakmoon91 secret 4 <EDITED>
redundancy
ip tcp synwait-time 10
no ip ftp passive
class-map match-any CCP-Transactional-1
match dscp af21
match dscp af22
match dscp af23
class-map match-any CCP-Voice-1
match dscp ef
class-map match-any CCP-Routing-1
match dscp cs6
class-map match-any CCP-Signaling-1
match dscp cs3
match dscp af31
class-map match-any CCP-Management-1
match dscp cs2
policy-map sdm-qos-test-123
class class-default
policy-map CCP-QoS-Policy-1
class CCP-Voice-1
  priority percent 33
class CCP-Signaling-1
  bandwidth percent 5
class CCP-Routing-1
  bandwidth percent 5
class CCP-Management-1
  bandwidth percent 5
class CCP-Transactional-1
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 2
crypto isakmp key <EDITED> address 97.XXX.78.222    no-xauth
crypto isakmp key <EDITED> address 67.XXX.146.158
crypto isakmp client configuration group PlatinumVPNPool
key <EDITED>
dns 10.41.14.10 192.168.10.3
wins 10.41.14.10 192.168.10.3
domain <EDITED>
pool SDM_POOL_1
acl 108
include-local-lan
split-dns <EDITED>
pfs
max-users 25
max-logins 10
banner ^CYou are now connecting to a secure network. All connections are monitiored. If you have reached this in error please disconnect now. Call the Helpdesk X1000 for more information.^C
crypto isakmp profile ciscocp-ike-profile-1
   match identity group PlatinumVPNPool
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set PlatinumTransform esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile CiscoCP_Profile1
set security-association lifetime seconds 10800
set security-association idle-time 1800
set transform-set ESP-3DES-SHA
set pfs group2
set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to 97.xxx.78.222
set peer 97.XXX.78.222
match address 104
crypto map SDM_CMAP_1 2 ipsec-isakmp
description Tunnel to 67.xxx.146.158
set peer 67.XXX.146.158
set transform-set PlatinumTransform
match address 110
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ETH_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address 71.XXX.160.123 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast reverse-path
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ETH-LAN$$ETH-LAN$$FW_INSIDE$
ip address 10.41.14.100 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
service-policy output CCP-QoS-Policy-1
interface GigabitEthernet0/2
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface Virtual-Template1 type tunnel
ip unnumbered GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
ip local pool SDM_POOL_1 192.168.26.1 192.168.26.50
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 25
sort-by bytes
cache-timeout 3600
no ip nat service sip udp port 5060
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.41.14.103 80 71.XXX.160.123 80 extendable
ip nat inside source static tcp 10.41.14.103 443 71.XXX.160.123 443 extendable
ip route 0.0.0.0 0.0.0.0 71.XXX.160.121
ip route 10.67.188.32 255.255.255.224 10.41.14.99 6 permanent
ip route 10.67.188.96 255.255.255.224 10.41.14.99 8 permanent
ip route 10.200.107.0 255.255.255.0 10.41.14.99 9 permanent
ip route 10.200.110.0 255.255.254.0 10.41.14.99 7 permanent
ip route 74.200.107.0 255.255.255.0 10.41.14.99 5 permanent
ip route 74.200.110.0 255.255.254.0 10.41.14.99 4 permanent
ip route 208.67.188.32 255.255.255.224 10.41.14.99 2 permanent
ip route 208.67.188.96 255.255.255.224 10.41.14.99 3 permanent
ip sla auto discovery
logging trap errors
logging host 192.168.10.29
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 remark Platinum LAN
access-list 2 permit 10.41.14.0 0.0.0.255
access-list 2 deny   any
access-list 101 remark Master Rules
access-list 101 remark CCP_ACL Category=1
access-list 101 remark Asterisk VOIP
access-list 101 permit object-group Asterisk any any
access-list 101 remark FaxFinder WWW Traffic
access-list 101 permit tcp any host 71.XXX.160.123 eq www
access-list 101 remark FaxFinder HTTPS Traffic
access-list 101 permit tcp any host 71.XXX.160.123 eq 443
access-list 101 remark NTP Time Protocol
access-list 101 permit udp any host 71.XXX.160.123 eq ntp
access-list 101 remark IPSEC Protocols
access-list 101 permit udp any host 71.XXX.160.123 eq non500-isakmp
access-list 101 permit udp any host 71.XXX.160.123 eq isakmp
access-list 101 remark ESP Traffic
access-list 101 permit esp any host 71.XXX.160.123
access-list 101 remark General Permit
access-list 101 permit ip any any
access-list 102 remark CCP_ACL Category=2
access-list 102 remark IPSec Rule
access-list 102 deny   ip 10.41.14.0 0.0.0.255 10.0.2.0 0.0.0.255
access-list 102 deny   ip 10.41.14.0 0.0.0.255 192.168.10.0 0.0.0.31
access-list 102 remark Platinum LAN NAT Rule
access-list 102 permit ip 10.41.14.0 0.0.0.255 any
access-list 104 remark CCP_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.41.14.0 0.0.0.255 192.168.10.0 0.0.0.31
access-list 108 remark CCP_ACL Category=4
access-list 108 permit ip 10.41.14.0 0.0.0.255 any
access-list 110 remark CCP_ACL Category=4
access-list 110 remark IPSec Rule
access-list 110 permit ip 10.41.14.0 0.0.0.255 10.0.2.0 0.0.0.255
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 102
snmp-server community <EDITED> RW
snmp-server community public RO
snmp-server location Clearwater North
snmp-server contact MIS IT Services x1000
snmp-server enable traps entity-sensor threshold
snmp-server host 192.168.10.29 Mccullour9320
control-plane
banner login ^CYou have reached a security checkpoint. All connections are monitored. Follow company usage guidelines. Please contact the MIS IT Department for more information at x1000.^C
line con 0
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 <EDITED>
transport input telnet ssh
transport output telnet ssh
line vty 5 15
scheduler allocate 20000 1000
ntp update-calendar
ntp server 24.56.178.140 prefer source GigabitEthernet0/0
ntp server 64.239.96.53 source GigabitEthernet0/0
ntp server 96.226.123.157 source GigabitEthernet0/0
ntp server 64.113.32.5 source GigabitEthernet0/0
ntp server 129.6.15.30 prefer source GigabitEthernet0/0
ntp server 12.10.191.151 source GigabitEthernet0/0
end
804
