CISCO 2911 SIP to PRI
I am trying to get a cisco 2911 with E1/T1 cards installed to take a sip call and make outbound call over the T1 or PRI board..  In the past I used the 3800 series and I required to purchase DSP resources in order to setup the T1  as follows
controller T1 0/0/0
framing esf
 linecode b8zs
 pri-group timeslots 1-24
The issue is that unless you have DSP resources it will not allow you to setup..  I recently took a router (2911) in production out but had to reset it and once I tried to setup the system gave me not enough resources available..  DO you know another way the previous person could have accomplished the same?
You might have more T1/E1s,
You might have more T1/E1s, FXO, FXSs, etc. or some other config (MTP, XCODER, etc) that takes up DSPs, and you not have enough for all those endpoints, you would need to shut down the ones you're not using, or free resources from media resources configured to free up enough DSP channels to configure that T1
Look at your inventory and current config to see what you have.
java
if this helps, please rate
www.cisco.com/go/pdi
show inventory gives me this.
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V05 , SN: FTX1618A075
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1  , VID: V01 , SN: FOC1750880C
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1  , VID: V01 , SN: FOC175087WP
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 , SN: FOC18036Y6E
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC161267U3
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC16164BSP
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V04 , SN: DCA1606R49K
133
