04-30-2012 11:49 AM - edited 03-16-2019 10:54 AM
Hello All,
I am having trouble with outboud SIP PSTN calls through a Cisco 2911 Voice Gateway. 2911 VG terminates PSTN SIP Traffic and connects to Avaya CS1000M via QSIG PRI Trunks. When calls are attempted outbound fron the PBX the caller gets a fast busy. Debug ISDN q931 shows the call hitting the 2911 properly, debug voip ccapi inout shows the call matching the correct dial peers and debug ccsip shows the invite to the PSTN Provider SBC, however within the invite the "from" address incorrectly shows the calling number with the provider SBC address (see below). does anyone have any insight on how to correct this? Attached are VG config and Debug isdn q931, voip ccapi inout, ccsip messages and ccsip call. Thanks in advance for any help!!
To: <sip:7022444138@74.4.9.21>
Shawn C. Smith
Solved! Go to Solution.
05-03-2012 08:32 AM
Shawn,
Here is the analysins of whats going on from your trace..
On your Voip CCAPI debug..
we see 1st call setup..this is our inbound leg..
Apr 30 15:39:54.527: //-1/9128787D8010/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=7026672375
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=7022444138
This matches inbound dial-peer 1 (with a callid=11214)
Incoming Dial-peer=1,
Next we see the outbound call leg call setup (call id -11215)
Outgoing Dial-peer=15,
Apr 30 15:39:54.531: //11214/9128787D8010/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=7022444138
Next we get look at the sip debug...
On the SIP trace or leg of the call
An invite was sent to 7022444138@74.4.9.21:6000 SIP/2.0, ( I take it that 74.x.x.x.x is the CUBE sending the call to the PSTN). If that is correct, then this uri is fine.
Sent:
INVITE sip:7022444138@74.4.9.21:6000 SIP/2.0
Via: SIP/2.0/UDP 138.210.154.41:6000;x-route-tag="tgrp:QSIG";branch=z9hG4bK1504233C (NB this is the device where the call originates from)
The problem is in the FROM URI.. (as you mentioned). The from uri shows that the call is originating from the CUBE you are sending it to...(highlighted in red)
To: <7022444138>7022444138>
However the remote party id shows the correct uri..
Remote-Party-ID: <7026672375>7026672375>>;party=calling;screen=no;privacy=off
+++This field shows the device where the call originates from.
o=CiscoSystemsSIP-GW-UserAgent 8833 3560 IN IP4 138.210.154.41
s=SIP Call
c=IN IP4 138.210.154.41
So deally your from uri should look like From: <7026672375>7026672375>
Next the CUBE received an Invite of the same call that it sent an invite for.. (ideally it should receive a trying from the far end)
Remote-Party-ID: <7026672375>;party=calling;screen=no;privacy=off7026672375>
Apr 30 15:39:54.539: //-1/9128787D8010/CCAPI/cc_api_display_ie_subfields:
cisco-username=7026672375
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7022444138
pr 30 15:39:54.539: //11216/9128787D8010/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=7026672375(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=7022444138(TON=Unknown, NPI=Unknown))
Apr 30 15:39:54.543: //11216/9128787D8010/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Sent:
SIP/2.0 403 Forbidden
voice class sip-profiles 10
request REFER sip-header Refer-To modify "10.66.75.245" "10.66.81.91"
Then to confirm that the same call came back to it, the cube got a call setup request for the call its attempting to place on ibound dial-peer 4)
Incoming Dial-peer=4, Progress Indication=NULL(0) with a new callid=1126
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7022444138
Apr 30 15:39:54.539: //11216/9128787D8010/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Next we get a disconnect on this call leg..( and a Toll_fraud error)
>>>>CCAPI handed cid 11216 with tag 4 to app "_ManagedAppProcess_TOLLFRAUD_APP"
This showed that the far end, which is the called end is saying that you cant originate a call if you are not here (something in that line)
On the sip leg we see the following
The CUBE sends a trying after it to go an look for the called number..
Sent:
SIP/2.0 100 Trying
To: <7022444138>7022444138>7026672375>
++++But it responds with a Forbidded++++
Sent:
To resolve this you need to do the following:
request invite sip-header From modify "74.4.9.21" "138.210.154.41"
dial-peer voice 15 voip
voice-class sip profiles 10
This way when a call comes in inbound on dial-peer 1, the from field will read 7.....@138.210.154.41
This configuration assume that the device "138.210.154.41" is the only one that your calls originate from..
HTH...
04-30-2012 04:24 PM
Shawn,
Looks like you call is being rejected by ANTI TOLL FRAUD
Apr 30 15:39:54.539: //11216/9128787D8010/CCAPI/cc_process_call_setup_ind:
Apr 30 15:39:54.539: //11216/9128787D8010/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Apr 30 15:39:54.543: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
show ip address trusted list
Can you post the output of
Make sure that distination address of your SIP server is in the list.
The link for ANTI TOLL FRAUD is:-
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml#t3
Alex
05-02-2012 03:56 PM
Thanks for the reply Alex! I Had the Provider SBC Address set as trusted (see capture below) and it does show up as trusted. In my original post you can see that the "from" address shows as 7026672375@74.4.9.21 when it should be 7026672375@
Shawn C. Smith
UBC.2911-2#show ip address trusted list
IP Address Trusted Authentication
Administration State: UP
Operation State: UP
IP Address Trusted Call Block Cause: call-reject (21)
VoIP Dial-peer IPv4 Session Targets:
Peer Tag Oper State Session Target
4 UP ipv4:74.4.9.21
IP Address Trusted List:
ipv4 74.4.9.21
05-03-2012 03:21 AM
Have you configuredbind interface under sip?
05-03-2012 07:48 AM
Thanks for the reply Paolo!! Yes I have configurd "bind control source-interface" and "bind media source-interface".
Shawn C. Smith
05-03-2012 08:32 AM
Shawn,
cisco-username=
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=7022444138
ccCallSetupRequest:
cisco-username=
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=7022444138
Sent:
s=SIP Call
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7022444138
Set Up Event Sent;
Sent:
SIP/2.0 100 Trying
Sent:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7022444138
Set Up Event Sent;
Sent:
SIP/2.0 100 Trying
Sent:
HTH...
05-05-2012 02:37 PM
Shawn,
Did you get this problem fixed. I am just curious to know how it was resolved
05-11-2012 08:13 AM
aokanlawon,
I apologize for the delayed reply, however I had to wait for th provider to be available to test. Yes, This has been fixed using the method that you described above. I can now see the correct information in the SIP messages, as does the provider SBC. Thanks so much!!
Shawn C. Smith
06-01-2012 06:17 PM
I didnt see your post until today. I am really delighted this fixed the issue. Thanks for the nice rating
Please rate useful posts
06-01-2014 12:12 AM
i have same problem my cucm ip is 192.168.200.53
my Voice Gateway is SIP by ip 192.168.200.86 for internal
and 172.29.7.94
and my SIP Server is 10.208.9.69
if its oky can yuo take a look at my problem please
this is the syslog from debug
May 30 20:19:34.284: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90555769123@192.168.200.86:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.200.53:5060;branch=z9hG4bK3bd451bf17e0
From: "Aysar Mohamed" <sip:2217156@192.168.200.53>;tag=37693~244641b0-36ac-434c-91c1-823f25a68b28-18299026
To: <sip:90555769123@192.168.200.86>
Date: Fri, 30 May 2014 20:19:34 GMT
Call-ID: b5a49480-3881e7d6-13a9-35c8a8c0@192.168.200.53
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:192.168.200.53:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3047462016-0000065536-0000004549-0902342848
Session-Expires: 1800
P-Asserted-Identity: "Aysar Mohamed" <sip:2217156@192.168.200.53>
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@192.168.200.53>;party=calling;screen=yes;privacy=off
Contact: <sip:2217156@192.168.200.53:5060>
Max-Forwards: 70
Content-Length: 0
May 30 20:19:34.284: //-1/B5A494800000/CCAPI/cc_api_display_ie_subfields:
cisco-username=2217156
cisco-ani=2217156
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=90555769123
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 30 20:19:34.288: //-1/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x30CF41D4, Call Info(
Calling Number=2217156,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90555769123(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=465
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 30 20:19:34.288: :cc_get_feature_vsa malloc success
May 30 20:19:34.288: cc_get_feature_vsa count is 1
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832953048,feature_id:85
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90555769123(TON=Unknown, NPI=Unknown))
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_process_call_setup_ind:
Event=0x2B82D890
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 90555769123
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetContext:
Context=0x2ABC2E44
>>>>CCAPI handed cid 465 with tag 0 to app "_ManagedAppProcess_Default"
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallProceeding:
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=802, Params=0x2ABC19D4, Progress Indication=NULL(0)
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCheckClipClir:
In: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Destination Pattern=9T, Called Number=0555769123, Digit Strip=FALSE
Called Number=0555769123(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Aysar Mohamed
Account Number=2217156, Final Destination Flag=TRUE,
Guid=B5A49480-0001-0000-0000-11C535C8A8C0, Outgoing Dial-peer=802
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=2217156
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0555769123
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x30CF41D4, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=2217156,(Calling Name=Aysar Mohamed)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0555769123(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=802, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 30 20:19:34.288: cc_get_feature_vsa count is 2
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832952824,feature_id:86
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccCallSetContext:
Context=0x2ABC1984
May 30 20:19:34.292: //465/B5A494800000/CCAPI/ccSaveDialpeerTag:
May 30 20:19:34.292: //466/B5A494800000/CCAPI/cc_api_call_proceeding:
Interface=0x30CF41D4, Progress Indication=NULL(0)
May 30 20:19:34.292: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
May 30 20:19:34.292: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0555769123@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK461C
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@172.29.7.94>;party=calling;screen=yes;privacy=off
From: "Aysar Mohamed" <sip:2217156@172.29.7.94>;tag=7394E4-1898
To: <sip:0555769123@10.208.9.69>
Call-ID: 8C9F6977-E76E11E3-8277BE8C-EC3B12A0@172.29.7.94
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1401481174
Contact: <sip:2217156@172.29.7.94:5060>
Call-Info: <sip:172.29.7.94:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
Content-Length: 0
May 30 20:19:34.300: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Aysar Mohamed"<sip:2217156@172.29.7.94>;tag=7394E4-1898
CSeq: 101 INVITE
Content-Length: 0
May 30 20:19:34.612: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Record-Route: <sip:10.208.9.69:5060;transport=udp;lr>
To: <sip:0555769123@10.208.9.69>;tag=sbc0806eppk5yip-CC-57
CSeq: 101 INVITE
Contact: <sip:0555769123@10.208.9.69:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 328
Content-Type: application/sdp
v=0
o=- 17192647 17192647 IN IP4 10.208.9.69
s=SBC call
c=IN IP4 10.208.9.69
t=0 0
m=audio 39910 RTP/AVP 8 0 102 102 18 116
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:102 AMR/8000
a=rtpmap:18 G729/8000
a=rtpmap:116 telephone-event/8000
a=ptime:5
a=fmtp:116 0-15
a=fmtp:18 annexb=yes
May 30 20:19:34.612: %SIP-3-UNSUPPORTED: Unsupported ptime value
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=466,
Caps(Codec=0x2, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
May 30 20:19:34.612: //465/B5A494800000/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=465,
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=3882)
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_event_indication:
Event=170, Call Id=466
Event Is Sent To Conferenced SPI(s) Directly
Event=98, Call Id=466
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_call_cut_progress:
Interface=0x30CF41D4, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
Cause Value=0
Call Entry(Responsed=TRUE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccConferenceCreate:
(confID=0x30C11410, callID1=0x1D1, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //466/B5A494800000/CCAPI/ccConferenceCreate:
(confID=0x30C11410, callID2=0x1D2, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/ccConferenceCreate:
Conference Id=0x30C11410, Call Id1=465, Call Id2=466, Tag=0x0
May 30 20:19:34.616: //465/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: cc_api_get_xcode_stream : 4702
May 30 20:19:34.616: //466/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=0, dtmf1=0
ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=8, rx_dynamic_pt2=8, codec_mode2=0, params_bitmap2 =0
delay media to slow start case, codec negotation is not done
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_api_bridge_done:
Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=465,
Destination Call Id=466, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //466/B5A494800000/CCAPI/cc_api_bridge_done:
Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=466,
Destination Call Id=465, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x16, Destination Call Id=466)
Call Entry(Conference Id=0x16, Destination Call Id=465)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x16, Call Id1=465, Call Id2=466
May 30 20:19:34.616: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90555769123@192.168.200.86>;tag=739628-1BDB
CSeq: 101 INVITE
Remote-Party-ID: <sip:0555769123@192.168.200.86>;party=called;screen=yes;privacy=off
Contact: <sip:90555769123@192.168.200.86:5060>
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 233
v=0
o=CiscoSystemsSIP-GW-UserAgent 2639 5276 IN IP4 192.168.200.86
s=SIP Call
c=IN IP4 192.168.200.86
t=0 0
m=audio 18288 RTP/AVP 8 0 19
a=rtpmap:19 CN/8000
May 30 20:19:34.680: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
CSeq: 101 INVITE
Reason: Q.850;cause=127;text="interworking unspecified"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x30CF41D4, Call Id=466
Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 30 20:19:34.680: //466/B5A494800000/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=466
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccConferenceDestroy:
Conference Id=0x16, Tag=0x0
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
Sent:
ACK sip:0555769123@10.208.9.69:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.684: //466/B5A494800000/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
May 30 20:19:34.684: //466/B5A494800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=466,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.684: :cc_free_feature_vsa freeing 31A5D9F0
May 30 20:19:34.684: vsacount in free is 1
May 30 20:19:34.684: //465/B5A494800000/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 30 20:19:34.684: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=41
Content-Length: 0
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:90555769123@192.168.200.86:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.688: //465/B5A494800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=465,
May 30 20:19:34.688: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.688: :cc_free_feature_vsa freeing 31A5DAD0
May 30 20:19:34.688: vsacount in free is 0
May 30 20:19:36.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.29.7.94:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKmisco3ykfiooegpygsphkocp1T20326
Call-ID: isbcfemyk1p1mkteets1tcmi53eeehfhikcp@SoftX3000
To: <sip:172.29.7.94>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
May 30 20:19:36.048: //467/8DAABF6C8278/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.29.7.94>;tag=739BBC-1CE2
Date: Fri, 30 May 2014 20:19:36 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 3496 1601 IN IP4 172.29.7.94
s=SIP Call
c=IN IP4 172.29.7.94
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
My SIP GW internal ip address is 192.168.200.86
and the Public IP is : 172.29.7.94
My CUCM is 192.168.200.53
my GW Config is :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 3
rule 1 /^9\(\)/ /\1/
voice translation-rule 4
rule 4 /^22217/ /7/
rule 5 /^2217/ /7/
rule 6 /^022217/ /7/
rule 7 /^0122217/ /7/
voice translation-rule 5
rule 1 /^5/ /905/
rule 2 /^1/ /901/
rule 3 /^2/ /902/
rule 4 /^3/ /903/
rule 5 /^4/ /904/
rule 6 /^6/ /906/
rule 7 /^7/ /907/
rule 8 /^8/ /908/
rule 10 /^00/ /900/
rule 11 /'+'/ /900/
voice translation-profile OUT
translate called 3
voice translation-profile REDIAL
translate calling 5
voice translation-profile SIP-NEW
translate called 4
application
service mva http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
service ccm http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
license udi pid CISCO2921/K9 sn FCZ164960G0
hw-module pvdm 0/0
hw-module pvdm 0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.200.86 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.29.7.94 255.255.255.252
duplex auto
speed auto
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip route 10.208.9.0 255.255.255.0 172.29.7.93
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.200.53 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register NAGHI-MTP
dspfarm profile 2 mtp
codec g711alaw
maximum sessions hardware 25
associate application SCCP
dial-peer voice 802 voip
description ** SIP TO STC **
translation-profile outgoing OUT
destination-pattern 9T
session protocol sipv2
session target ipv4:10.208.9.69:5060
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay sip-notify rtp-nte sip-kpml
no vad
dial-peer voice 811 voip
description ** SIP INCOMING FROM STC **
translation-profile incoming SIP-NEW
translation-profile outgoing REDIAL
destination-pattern 7...
session target ipv4:192.168.200.53
incoming called-number 022217...$
codec g711alaw
dial-peer voice 812 voip
incoming called-number 22217...$
codec g711alaw
dial-peer voice 813 voip
incoming called-number 2217...$
codec g711alaw
dial-peer voice 814 voip
preference 1
session target ipv4:192.168.200.63
codec g711alaw
dial-peer voice 815 voip
preference 1
codec g711alaw
dial-peer voice 816 voip
preference 1
codec g711alaw
dial-peer voice 817 voip
incoming called-number 0122217...$
codec g711alaw
dial-peer voice 818 voip
preference 1
codec g711alaw
Please i need ur help ASAP
