Cisco 2921 PVDM3 Resources
I am working on a Cisco 2921 router ordered with PVDM3 32 to 128 Channels factory upgrade. The DSP looks good in the inventory. However, I am not able to see / allocate all the resources available. I am unable to allocate more resources then currently are defined for Transcoding, Conferencing and MTP. Do I need to activate / license something ?
# show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FGL172222P8, Hw Revision: 1.0"
PID: CISCO2921/K9      , VID: V08 , SN: FGL172222P8
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128         , VID: V01 , SN: FOC170260AM
# show dsp-group  all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 32.1.2
  Max signal/voice channel: 43/43
  Max credits: 645, Voice credits: 645, Video credits: 0
  num_of_sig_chnls_allocated: 43
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 645, reserved credits: 0
    Signaling channels allocated: 43
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
  num_of_sig_chnls_allocated: 17
  Transcoding channels allocated: 12
    Shared credits: 258, reserved credits: 0
    Signaling channels allocated: 17
  Group: FLEX_GROUP_XCODE, complexity: HIGH
    Shared credits: 0, reserved credits: 387
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 3:
  Max signal/voice channel: 42/43
  num_of_sig_chnls_allocated: 0
  Transcoding channels allocated: 7
    Shared credits: 27, reserved credits: 0
    Signaling channels allocated: 0
    Shared credits: 0, reserved credits: 97
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 461
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 7
  Group: FLEX_GROUP_HW_MTP, complexity: LOW
    Shared credits: 0, reserved credits: 60
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
#  show dspfarm all
Dspfarm Profile Configuration
Profile ID = 3, Service = TRANSCODING, Resource ID = 1
Profile Description : XCODE Resources
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 15
Number of Resources Out of Service : 0
Codec Configuration: num_of_codecs:5
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 2, Service = CONFERENCING, Resource ID = 2
Profile Description : Conference Resouces
Number of Resource Configured : 5
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Profile ID = 1, Service = MTP, Resource ID = 3
Profile Description : MTP Resources
Number of Resource Configured : 4
Hardware Configured Resources : 4
Hardware Available Resources : 4
Software Resources : 0
Codec Configuration: num_of_codecs:1
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    2   32.1.2   UP     N/A  FREE  xcode   1      -         -         -
0    3   32.1.2   UP     N/A  FREE  xcode   1      -         -         -
0    3   32.1.2   UP     N/A  FREE  conf    2      -         -         -
0    3   32.1.2   UP     N/A  FREE  mtp     3      -         -         -
Total number of DSPFARM DSP channel(s) 24
Rick.
VIP Purple
Hi Rick,
You do not need any license to activate PVDMs .U need to have Voice based IOS.
But on ISR G2 series ,in addition to Voice based IOS , also need Unified Communications license. In your case,it is alreay there since u are able to see//configure PVDMs.
Please refer this DOC by Mr. AOK
https://supportforums.cisco.com/docs/DOC-29151
Can u share the output of command show voice dsp group all.
regds,
aman
Re: Cisco 2921 PVDM3 Resources
Thanks Aman
The output of "show voice dsp group all" follows below:
#show voice dsp group all
dsp 1:
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 3:
    Sessions per dsp: 7
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
  0 DSP resource allocation failure
Why are the  total channels in the output of DSP Farm command equal to 24 only ?
Rick.
VIP Purple
Hi Rick,
It is a good catch .I have never seriously noticed in  O/P but this may be due to Number of Resource Configured which sums to 24[15+5+4] .
regds,
aman
Thanks Aman,
Yes, that may be sum of total resources configured. However, I cannot increase the individual count beyond 15, 5 and 4 without decreasing another number. The DSP config looks like this:
voice-card 0
dsp services dspfarm
dspfarm profile 3 transcode
description XCODE Resources
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 15
associate application SCCP
dspfarm profile 2 conference
description Conference Resouces
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
dspfarm profile 1 mtp
description MTP Resources
codec g711ulaw
maximum sessions hardware 4
Rick.
If you are concern about the DSP utilization, please go ahead and check it with the DSP calculator:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
1264
