08-13-2014 03:56 PM - edited 03-16-2019 11:44 PM
Solved! Go to Solution.
08-13-2014 07:12 PM
08-14-2014 02:32 AM
Yes - you need PVDMs. All Cisco VOIP cards need PVDMs.
Aaron
08-13-2014 05:30 PM
What does show diag and show inventory give you?
08-13-2014 07:08 PM
Hi George,
It's
R2#show inventory
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825 , VID: V03 , SN: FHK1045F0EM
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 0", DESC
R: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID= , VID: 3.1, SN: JAE083202F9
R2#
08-13-2014 07:12 PM
You need to have PVDMs installed .
regds,
aman
08-13-2014 07:13 PM
Hi Aman,
Are you %100?
08-13-2014 07:58 PM
Yes...
can u share show runn?
regds,
aman
08-14-2014 02:32 AM
Aaron
08-14-2014 04:00 AM
08-13-2014 07:12 PM
Then show voice port
R2#show voice port
EFXS 50/0/1 Slot is 50, Sub-unit is 0, Port is 1
Type of VoicePort is EFXS
Operation State is UP
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 5 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Station name Sarah, Station number 9055645636
Caller ID Info Follows:
Standard BELLCORE
Translation profile (Incoming):
Translation profile (Outgoing):
Digit Duration Timing is set to 100 ms
EFXS 50/0/2 Slot is 50, Sub-unit is 0, Port is 2
Station name Erik, Station number 2
Standard BELLCORE
R2#
