03-28-2012 03:33 AM - edited 03-16-2019 10:20 AM
I know ive missed something simple here...
We are going to deploy a bunch of 3905 IP phones so i bought one in just to check if they are up to the task. Ive uploaded the firmware to TFTP and restarted the service but i still cannot see the 3905 as an avaliable device. Ive done device firmware upgrades before but only on devices that existed already.
My CUCM is
8.5.1.11900-21
What have i missed?
Best wishes
Jon
03-28-2012 03:45 AM
03-28-2012 03:47 AM
because what i know, you need a cop file. then your cucm should support the device (devicelist). firmware is an other story.
Posted by WebUser Nicht Therapierbar
03-28-2012 03:55 AM
Sure did,
cmterm-3905.9-2-2-0.cop.sgn
I think i might need to install this QED too, i will try now
03-28-2012 04:01 AM
Yes you need above cop file and This device pack is needed.
cmterm-devicepack8.5.1.14059-1.cop.sgn
Ronak Patel
Please rate helpful posts.
03-28-2012 04:14 AM
No, i just needed the QED file too.
All sorted.
Cheers
Jon
03-28-2012 05:35 AM
....spoke too soon. If anyone else has this and then the phones still do not register you need to reboot the cluster
03-28-2012 05:40 AM
HI
Ronak Patel
03-28-2012 05:46 AM
Yes i restated TFTP after the installs.
The phone has this message in the status
File Not Found : English_United_Kingdom/cin-sip.jar
There are two different instances of this on the forums both of which were only resolved after a reboot.
/Jon
