Cisco 3905 SIP phones registration error and provisioning
Dear Experts,
I have cluster of fo CUCM 8.0, I have 3905 phones. the phones flaps between registered and provisioning state.?
phone firmware is 9.4(1).
do you have any idea why this is happening
thanks in advance
Anas
Everyone's tags (2)
VIP Purple
Hi Anas,
Have u uploaded QED for this firmware on Call manager ? there is a bug associated with this firmware  which could be the cause of problem
9.4(1) QED and locales check in for 3905 phone
CSCuh23600
Symptom:
The purpose of this check in is to add the 9.4(1) firmware and the related support files for Cisco IP Phone model 3905 to supported CUCM branches
Conditions:
ccm 10.0
Workaround:
none
But surprisingly I am asking you but not able to find QED for 9.4(1) on cisco site.
Can u try degrading fimrware to 9.2(2) since enabler is available for this firmware and check?
regds,
aman
Hi Amman,
I use the QED 9.2(1) when I enable the phone on CUCM 8. then I upload firmware 9.2(1). I register the phones on this version.
after that I did the upgrade to firmware version 9.4(1), I will try to downgrade and check
this is issue is really weird.
thanks
Anas
VIP Purple
Hi Anas,
There would be  a separate QED for SIP 3905 9.4(1) which I am also not able to locate on Cisco site.
Try degrading to 9.2(1) and check the registration/provisioning issue.
regds,
aman
I'm using 3905 s with CUCM 9.1.1, its stable with "CP3905.9-4-1-0", but before upgrading to 9.4 it gaved lot of issues such as Re-registering, Quality issues and hung in Provisioning state.
Regds
VIP Purple
Hi Fernando,
Did u upload QED file for 9.4(1) on CUCM ?
if possible, can u share show active version.
regds,
aman
I'm having the same issue but
I'm having the same issue but using CUCM 10.5 with Cisco 3905 phones.
Fail to register the phone in all three firmwares (9.2.1, 9.2.2 and 9.4.4) with QEDs (expect for 9.4.1). It gets stuck in provisionig and registering states.
Rodrigo
Hi Rodrigo,did you get this
Hi Rodrigo,
did you get this issue solved ¿? i'm having the same problem with CUCM10.5 with Cisco 3905 phones and Firmware .9-4-1-0.
Rgds
Vicente
Hi,try to downgrade the
try to downgrade the firmware and check it again
Anas
I have the same issue with the 3905 flapping between Registered and Provisioning
CUCM Version: 8.6.2.25900-8
3905 Firmware: CP3905.9-4-1SR2-2
What could be causing this issue?
Leonardo Santana
Re: Hello,
check DHCP scope? looks like DHCP pool is full...
3694
