06-19-2014 04:58 AM - edited 03-16-2019 11:09 PM
Hi guys,
I migrated from 2821 CUME on 3925 CUME, on the 2821 had E1 link and IVR script it was working fine, after that I copy same script on new box (3925) and add on incoming dial-peer which is connect on new ISP with SIP trunk.
Please for help!
Thank you in advance.
Tom
06-19-2014 05:16 AM
Could you post configs and script to give us a little bit more info?
BR,
Dragan
06-19-2014 05:57 AM
Do you have a transcoder? Did you configure the appropriate dtmf-relay and codec?
Yosh
06-21-2014 05:34 AM
Hi Yosh
I have configured DSP :
c3925-vgw#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 2
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 1
Number of Resources Out of Service : 0
Codec Configuration: num_of_codecs:6
Codec : g729br8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Number of Resource Configured : 3
Maximum conference participants : 8
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 32.1.3 UP N/A FREE xcode 2 - - -
0 2 32.1.3 UP N/A FREE conf 1 - - -
Total number of DSPFARM DSP channel(s) 4
And here is the voip dial peer:
dial-peer voice 9 voip
description SIP Trunk
translation-profile incoming inclid
service ivr-script
session protocol sipv2
session target dns:sip.provider.com
incoming called-number .
dtmf-relay rtp-nte
codec g711alaw
no vad
Tom
06-21-2014 05:35 AM
from the debug I saw how script can't catch call leg.
Tom
06-19-2014 09:36 PM
I was told that ivr script can work only on pots dial-peers and not work on voip dial-peers so I installed CUC servers with ivr script in addition to CUCM servers
06-19-2014 10:10 PM
Can you give me some advice How I can do this (some kind of example)
