Cisco 3925 CUME ivr script doesn't play on incoming voip dial-peer
Hi guys,
I migrated from 2821 CUME on 3925 CUME, on the 2821 had E1 link and IVR script it was working fine, after that I copy same script on new box (3925) and add on incoming dial-peer which is connect on new ISP with SIP trunk.
Please for help!
Thank you in advance.
Tom
  • IP Telephony
Silver
Could you post configs and
Could you post configs and script to give us a little bit more info?
BR,
Dragan
HTH, Dragan
Do you have a transcoder? Did
Do you have a transcoder? Did you configure the appropriate dtmf-relay and codec?
Yosh
HTH Regards, Yosh
Hi YoshI have configured DSP
Hi Yosh
I have configured DSP :
c3925-vgw#sh dspfarm all
Dspfarm Profile Configuration
 Profile ID = 2, Service = TRANSCODING, Resource ID = 2
 Profile Description :
 Profile Service Mode : Non Secure
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : SCCP   Status : ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 1
 Number of Resources Out of Service : 0
 Codec Configuration: num_of_codecs:6
 Codec : g729br8, Maximum Packetization Period : 60
 Codec : g729r8, Maximum Packetization Period : 60
 Codec : g711ulaw, Maximum Packetization Period : 30
 Codec : g711alaw, Maximum Packetization Period : 30
 Codec : g729ar8, Maximum Packetization Period : 60
 Codec : g729abr8, Maximum Packetization Period : 60
 Profile ID = 1, Service = CONFERENCING, Resource ID = 1
 Number of Resource Configured : 3
 Maximum conference participants : 8
 Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   32.1.3   UP     N/A  FREE  xcode   2      -         -         -
0    2   32.1.3   UP     N/A  FREE  conf    1      -         -         -
Total number of DSPFARM DSP channel(s) 4
And here is the voip dial peer:
dial-peer voice 9 voip
 description SIP Trunk
 translation-profile incoming inclid
 service ivr-script
 session protocol sipv2
 session target dns:sip.provider.com
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
Tom
from the debug I saw how
from the debug I saw how script can't catch call leg.
Tom
I was told that ivr script
I was told that ivr script can work only on pots dial-peers and not work on voip dial-peers so I installed CUC servers with ivr script in addition to CUCM servers
Hi Can you give me some
Can you give me some advice How I can do this (some kind of example)
75
