Cisco 3945e 15.1(2)T2 versus transfers in SRST
I have encountered a strange behaviour;
While the phones were in SRST, I made a call from an IP-phone to an external phone (my mobile).
Then, from that phone, I tried to transfer the call to an other IP-phone.
The transfer works fine, but IF I hang up on my mobile, when the transfer is made to the second IP-phone (before it is answered), this causes the Voice Router to crash and reboot.
I tried it a couple of time to be sure that this was the cause.
This is the message I can see (from show version):
System returned to ROM by bus error at PC 0x3F7F68B, address 0x3F7F68B at ...
I don't know is there are more commando's that could show the cause or any explanation.
Is this a known bug?
Best regards,
Antoine
Everyone's tags (4)
Hall of Fame Super Silver
Antoine,
This appears to be either some IOS bug or hardware issue, I would suggest upgrading IOS to 15.1.4M to see if you can reproduce, if it still occurs on that version I suggest you contact TAC.
HTH,
Chris
In addition I found the following bug, are you using SIP by any chance?
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq78217
CSCtq78217          Bug Details
ISRG2: Router reloads due to Segv exception process: CCSIP_SPI_CONTROL
Symptoms: A router crashes with the following information:
System returned to ROM by address error at PC 0xZZZZZZZZ, address 0xZZZZZZZZ
Conditions: The symptom is observed with CUBE + SIP.
Workaround: There is no workaround.
1st Found-In
15.1(3)T
Fixed-In
15.2(1.7)T
15.1(4)M1.6
15.2(1.6.9)PIH17
15.1(4)XB6
15.2(1)T1.11
Hello Chris,
I was also thinking about a bug...
I have been looking for a similar bug description but could not find any.
I don't use SIP.
Best regards,
Antoine
solved after upgrading to release c3900e-universalk9-mz.SPA.152-1.T1.bin
1324
