Cisco 4321 and Over head paging
neeraj.nair
We’ll be replacing an existing 2851 with overhead paging on the fx0 card.  The new router is a 4321 and will have both fx0 and E/M NIMs.
Looking for confirmation on which NIM the overhead paging should get moved to and is there a config example for the 4k’s?
Our config is as follows
voice-port 0/1/0
pre-dial-delay 0
output attenuation 10
description PAGING
dial-peer voice 6000 pots
description OH PAGING
max-conn 1
destination-pattern 1070
port 0/1/0
forward-digits 1
Jonathan Unger
Level 7
Level 7
Hi There,
Welcome to the support community!
If you are using plain old FXO on the old system and nothing has changed with the paging system, I would use the same card type on the new system (FXO NIM) and not use the E&M. The configuration for the new 4321 should be very similar to the original VGW.
- Jon
