Community Member
Cisco 6500 & SRW224P config help
I got a Linksys SRW224P and want to put a 7941G on it. The linksys is connected to Cisco 6500 gi2/48. I already did the Ip Add, subnet, gateway & it can see the network & the CCM by ping/traceroute. But the problem is the phone cannot register to the CCM4.1 but the Linksys can see the ip of CCM (vise versa).
Do I forgot anything else?
thanks
Community Member
Re: Cisco 6500 & SRW224P config help
Did you set a tftp server in dhcp for the phone. I'm assuming that this is on a seperate subnet to the rest of the phones.
Community Member
here's what I did:
Cisco 6500 =
put the gi2/48 to trunk mode
SRW224P =
1. change the Gi1 to trunk mode which is
2. management vlan is vlan100 same as the LAN
3. create voice vlan 127 then tagged eth1 where the phone is connected same voice vlan as the LAN
4.change eth1 to trunk as well
but neither the Linksys switch nor the Cisco 6500 cannot ping each other.
Did I miss something?
thanks
131
