Cisco 6921 - BE3000 - new DHCP server
We have few Cisco 6921 phones currently registered with our CUCUM BE3000.
We have migrated to a new AD DHCP server, but having problem with phones that are switched off and back on again. they don't simply register with the new DHCP server. CUCUM can ping and communicate to DHCP server, but phones that are restarted, have no luck. The phones there were left switched on, are working properly.
any idea what else needs to be changed/tested?
many thanks,
Ally
Everyone's tags (4)
1 ACCEPTED SOLUTION
Bronze
The forum needs a "I answered
The forum needs a "I answered my own question button" LOL
smiley
Bronze
Have you set the DHCP option
Have you set the DHCP option 150 on the scope to point to the BE3K?
Hi,we migrated DHCP records
we migrated DHCP records like-for-like. so there wasn't any need to modify the server apart from unauthorizing the old one and authorizing the new one.
However, spent some time on our gateway switch and discovered that IP helper for the voice vlan was pointing to the old DHCP server, hence the failure of relaying requests to the new server.
changed the IP helper IP address and everything seems to be working as normal.
regards,
Ally
Bronze
smiley
that's very true!!! thanks
that's very true!!! thanks for getting in touch anyway wink
cheers,
Ally
40
