Community Member
Cisco 7800 series ip phones
Hi All
cisco 7821 is configured with 8 speed dials however when you hit the down button it wil lonely show the first 6 ?
anyone have a resolution ?
You can still  dial the 7/8th speed dials but you cannot view them with the button (pressing down on the main button)  , pressing down gives you your speed dials (only 6) , pressing up gives you dial history (no limit)  ?
Cheers
Henry
1 ACCEPTED SOLUTION
Hi, If you would like to have
If you would like to have more, you may configure Abbreviated Dialing which will give the option to use 99 index codes on the phone keypad.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7821_7841_7861/10_1/english/admin_guide/PA2D_BK_AB3F74DA_00_admin-7821-7841-7861-10_0/PA2D_BK_AB3F74DA_00_admin-7821-7841-7861-10_0_chapter_01010.html#PA2D_RF_F4618A32_00
Murali
Hi Henry,I am able to
Hi Henry,
I am able to recreate this in my lab setup and do not see any setting which allows this number to be increased beyond six speed dials, it most definitely looks like working as designed.
Manish
Murali
368
