Cisco 7841 XML 4 Parse error - Corporate Directory
Hello all
we have a CUCM cluster on 10.5.1 and deployed a few hunderd 7841s. the firmware on the phone is sip78xx.10-1-1-9
when users go to the corporate directory the get  "XML 4 parse error" in order to fix  temporary fix the problem we have to reset the phone however after a few hours or days the problem comes back. we have an LDAP integration as well
any suggestions ?
1 ACCEPTED SOLUTION
Hi Cristobal,Just open a TAC
Hi Cristobal,
Just open a TAC case and request the firmware version 10.2.1.12ES1.
Same problem here with CUCM 9
Same problem here with CUCM 9.1.2 cluster, same firmware and 7861 Phones. But not all phones are affected at one time.
Would be nice to have a solution for that.
Juergen
hello Juergen take alook at
hello Juergen
take alook at this bug. this is what we're hitting:
XML Error on 78XX phones
CSCuq96598
Symptom:
XML error while accessing EM , Corporate directory on 78XX phones due to missing /mnt/flash2 partition.
Conditions:
Working Phone: rwfs1 (/mnt/flash) AND ubi2:rwfs2 (/mnt/flash2) : have no memory leakage
Problematic Phone : ubi1:rwfs1 (/mnt/flash) has memory problem and var/volatile goes 100 %.
SSH to the phone:
show disk
Filesystem 1K-blocks Used Available Use% Mounted on
ubi0:rootfs 65944 31008 34936 47% /
none 1024 44 980 4% /dev
tmpfs 16384 16384 0 100% /var/volatile
tmpfs 61780 0 61780 0% /dev/shm
ubi1:rwfs1 8600 1140 6984 14% /mnt/flash
Workaround:
Factory reset on problematic phones have bring them back with 2 partitions on some of the phones. This step may not resolve the issue for all phones.
Further Problem Description:
Thanks for the information.
We plan to upgrade the phones to 10.2(1.12) tomorrow because of some other bugs. But unfortunately this one is not fixed in that version. :-(
Juergen
we've been testing this
we've been testing this firmware for the past week sip78xx.10-2-1-12ES1
it seems to be working just fine. no more XML Parse errors
TAC has to publish this firmware to you though
Hi Cristobal,
jph
Cisco released cmterm-78xx.10
Cisco released cmterm-78xx.10-2-1-12SR1-4.cop.sgn on November 12th and it appears to contain this fix.
1113
