cisco 7906 phone registering rejected
hadelmahmoud
I have call manager 4.2 sr3 and some of the 7906 phones show this message registering rejected error:... when it try to register with call manger taking into your consideration i already have 7906 phones registered succesfully
chadlincoln
Level 3
Level 3
Make sure have the MAC address put in correctly. Also make sure you have the phone type correct as well. If push come to shove, turn on auto registration and let it auto register. Then turn auto-registration off after it registers.
Please rate if this helps.
first I would like to thank you for your fast replay , but already I have auto registeration on & after that message appear I turned it off and the same message still appear
Have you tried without autoregistration? (Manually)
