cisco 7911 & extension mobility
Hi all,
I configure a cisco call manager 5.0(2).
I m using only 7911 IP Phone.
i have enable extention mobility.
when i login with a profile i do not have the option to logout. I then connect to the call manger and logout.
could you please help?
Hall of Fame Super Red
Re: cisco 7911 & extension mobility
Hi Eric,
Make sure that you add the Extension Mobility Service to the users Logged In Profile. This way they will be able to select the EM Service to Log out from the phone.
Hope this helps!
Rob
Hi Rob,
It has worked.
Thks
Eric
please can you sharing those
please can you sharing those files with me  cisco 7911g extensions mobility with asterisk  i will be appreciate that thanks in advance
Already replied in another
Already replied in another thread, and the EM feature is a Cisco feature from CUCM, if you're using asterisk, you need to use the services it provides, and surely no guide from Cisco will work for that.
java
if this helps, please rate
www.cisco.com/go/pdi
1607
