Cisco 7911 G cannot connect to ccm 4.1.3
i am trying to connect the new cisco 7911 G phone to CCM 4.1.3 and its giving registration errror what could be the cause .how i can solve this issue i am waiting for your valuable reply
Re: Cisco 7911 G cannot connect to ccm 4.1.3
is it registration error or "Registration Rejected". if it's the latter - possibly you haven't enabled the auto-registration feature on the CM
i enabled the auto registration the problem with the device pack thanks for your reply
Hall of Fame Super Red
Hi Sunny,
You need at least SR1 on CCM 4.1.3 to support the 7911G;
7911G IP Phone - Supported CallManager Versions
Cisco CallManager version 4.1(3) SR1 or later
ciscocm.4-1-DevPack-25.3.exe, or later
Hope this helps!
Rob
Hi rob
thanks for your help i will install the dev pack and update the status.
209
