01-18-2012 09:57 AM - edited 03-16-2019 09:05 AM
hi,
I have ccm 4.1 and having issue with cisco 7912 phone only that voice quality issue and at same time when i ping the it give high latency other ip phone models(7940,7942 ) are working fine
Kindly advice
01-18-2012 11:07 AM
Hi Asim
Have you had a look to switch interface statistics if there are some errors such as CRC or collisions?
Let e know
Carlo
01-18-2012 11:16 AM
Hi Carlo,
As far as network is concern every thing is fine.No crc no errors on the same swtich cisco 7942 is working fine
01-18-2012 12:25 PM
What is the phone load/firmware version loaded presently in 7912 ? If older, did you try updating it to the latest ?
As you said, switch config looks fine & other phones has no issues, I can think of phoneload first & then of any hardware issues ( phone ethernet port etc )
GP.
