Cisco 7920 connectivity problems unregistering every so hour
Hi!
I have succesfully installed this cisco 7920 wifi phone, but for some reason sometimes the call is not terminated correctly meaning that phone doesnt ring at all, but the other user hears a ring tone, and then shows missed calls? there is no problem making outbound calls, no call drops or anything like that. The problem is receiving calls sometimes the call will be terminated correctly
and sometimes the call is not terminated correctly, i have included the logs
04/09/2007 11:22:27.386 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286>
04/09/2007 11:54:00.995 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286>
04/09/2007 12:12:33.757 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286 >
04/09/2007 16:27:35.773 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286 >
04/09/2007 17:24:09.201 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286 >
04/09/2007 18:24:42.602 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286 >
04/09/2007 18:31:46.394 CCM|DeviceUnregistered - Device unregistered. Device name.:SEP001BA17B0286 Device IP address.:192.168.11.144 Device type. [Optional]:30002 Device description [Optional].:Wifi-Phone Reason Code [Optional].:8 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:10.0.0.4|<CLID::StandAloneCluster><NID::10.0.0.4><CT::AlarmSEP001BA17B0286 ><DEV::SEP001BA17B0286 >
What could be wrong?
Thank you very much for your time and help!
Hall of Fame Super Gold
Re: Cisco 7920 connectivity problems unregistering every so hour
Which FW on the phone? Can you upgrade to the latest and try again?
Hi Paolo,
The FW is cmterm_7920.4.0-03-01, and I have also check the event viewer and this is error that i get
:Explanation: A device that has previously registered with cisco callmanager has unregistered. This event may be issued as part of normal unregistration event or due to some other reason such as loss of "keepalives"
Now this cisco 7920 is connected to a switch using trunk mode, the weird thing is that the voice lan is 10.0.0.9 and the data lan is 192.168.12.10, all other cisco devices have a 10.0.0.XXX ip address but the cisco 7920 have an ip belonging to the data lan 192.168.12.XXX, but the phone works great for moments although like it losses connection so may be the event viewer is right about the keepalives, but how can i modify this issue or can i check something else?
thank you again for your time
Hi Charlotte,
the FW is latest and the fact that the phone uses the "wrong" vlan should not be the root cause.
I would try monitoring the access point to see if there is loss of wi-fi connectivity right before the phone looses kepalives and deregister.
I have used a Radio Frecuency Analyzer and the channel that the AP is working is free of interference, this is what i have in the config in the switchport
FastEthernet0/9 is up, line protocol is up
Hardware is Fast Ethernet, address is 000c.8599.c189 (bia 000c.8599.c5
Description: VOICE & DATA
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:23, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
51058504 packets input, 3406825010 bytes, 0 no buffer
Received 497730 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 456796 multicast, 0 pause input
124265148 packets output, 3977620375 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Thank you again for your time and help
Make sure your ip helper address for the voice vlan is pointed to the dhcp server that servers the voice vlan.
I also have device unregistered errors on my 7920 phone. I have worked with TAC to extens out the keepalives for a remote site which brought my 7920s down to once to three times per day. I run WPA/TKIP+PSK on the APs (1100 series with key rotation. I am going to try and turn off the rotation on my voice vlan.
I also have the voice QoS optios checked, but no true per vlan QoS policy which will come next via TACs assistance.
I now have 4 sites running multiple 7920s in a mix of CCM and CME. I will keep you posted.
any update on this, i have the same scenario.
latest firmware is installed on 7920 and i have logs in the router as well as in the event viewer!!!
Good day
Do you see the phone disassociating the AP immediately before unregistering ?
Do you see the above NOT happening at night when the phone is stored close to the AP ?
Positive answers to the above questions would indicate a problem in the area of wi-fi connectivity.
Not sure,
but it could be that the users are moving around the office and there might be areas with no coverage.
I will check if this is happening.
Good day
177
