Community Member
Cisco 7921 Custom Background Image
Does anyone know how to configure a custom background image on a 7921. Is it similar to at 7900 models where you create a thumbnail and image .png file and List.xml file and upload via tftp to the CUCM server? If so what are the image requirements and directory for the 7921?
Thank you
Bronze
Re: Cisco 7921 Custom Background Image
I hope you are doing great.
Can you provide me the version of the complete version of the CUCM?
and also the firmware that you are running?
Community Member
The version of CUCM is 7.1.3
As far as I know, it's not possible to customize images for 7921s.
-- Adrián.
You can use phone designer for that
Table 2     Supported Cisco Unified IP Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/phone_designer/7.1/english/release/PDReleaseNote71.html#wp42849
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java,
I knew about phone designer, but didn't know it works for 7921s (5pts)
But it can be cumbersome if he wants to use it to for a bunch of phones...
-- Adrián.
573
