Cisco 7925g Connection failed
Hello ,,
After configuring VoWLAN as per the following document:
Voice over Wireless LAN 4.1 Design Guide
and adding a network profile on the 7925g wireless phone . I still get connection failed .
For those who had faced this issue before please comment any propable troubleshoot for this .
This issue is delaying a project delivery, so its urgent
Thanks all
Hall of Fame Super Gold
Describe your WLAN configurations and settings.
What is the error message when the phone tries to connect?
Further to what Leo has said:
What model of the 7925G are you using specifically? eg. CP-7925G-A-K9, CP-7925G-W-K9, CP-7925G-E-K9 etc
What country is the phone being deployed into?
if it is a W model, the AP will need world mode configured on the Dot11Radio interface to register with the network.
conf t
int Dot11Radio1
world-mode dot11d country XX (both, indoor, outdoor)
end.
It sounds like an identical issue I dealt with last week, and this solved the issue. Also check obviously the phone has the correct SSID (case sensitive) and password, as well as security mode.
HTH,
Nic.
Thanks Nic. The command fixed my issue.
You're welcome, glad I could help.
Hi Nic,
How can I configure interface dot11 on lightweight access point??
1589
