Cisco 7935- LOGIN soft key for after hour call exemptoin, with CCME 7.0
Hi All,
Can any one tell me does the after hour call block exemption- 'Login key' works with Cisco 7936.I am not able to find this soft key in the conference station. I even tried creating a soft-key template which includes the login softkey in it and applied it to the respective ephone, but still getting the same problem, no login softkey displaying on the phone. We are using CCME ver.7.0 and the conference phone is using the firmware 3-3-15 (The latest one I found in software downloads).
Hall of Fame Super Gold
Re: Cisco 7935- LOGIN soft key for after hour call exemptoin, wi
You may want to contact Cisco TAC about this, they will either officially confirm it as a product limitation, or provide a workaround or file a bug.
CME 10.5 registered 7935. Not getting login softkey.
295
