cisco 7937g conference in CUCME
i have cisco ip conference station 7937g
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-conference-station-7937g/product_data_sheet0900aecd806e021a.html
I have already registred this station in CUCME and make calls
But when you press "Conf"  button, nothing happens, cant initial Conference
All ohter sccp and sip phones can initiate conference
In cme config:
ephone-dn  8
 number 6409
 label Conference
 name Conference
 hold-alert 30 originator
ephone  8
 mac-address <mac-address>
 keep-conference
 button  1:8
2 ACCEPTED SOLUTIONS
Hi.Are you try to conference
Hi.
Are you try to conference an incoming call with conference button?
You can give a look to this bug https://tools.cisco.com/bugsearch/bug/CSCuh72935
Carlo
Please rate all helpful posts "The more you help the more you learn"
VIP Gold
Can you change the
Can you change the configuration as below and then test..
ephone-dn  8 dual-line
 number 6409
 label Conference
 name Conference
ephone  8
 conference drop-mode creator
 conference add-mode creator
 type 7937
 keep-conference
 button  1:8
Suresh
Hi.
Carlo
Incoming calls with
Incoming calls with conference are working but 7937 cannot initiate conference when i try conf button press
#show ephone 7937ephone-8[7]
i load last firmware file cmterm-7937-1-4-5-7-SCCP.cop.sgn
load 7937 cmterm-7937.cop.sgn
But its not helps me((
VIP Gold
Can you change the
 number 6409
 label Conference
 name Conference
ephone  8
 type 7937
 keep-conference
 button  1:8
Suresh
Thanks for answerGive me a
Thanks for answer
Give me a minute and I'll let you know if that helped or not
Thanks it helps me Conf button are working now but only two participants can use conference  . Third listen music
But other phones can initiate conference with three and four  participants
Maybe need to add an additional parameter?
Hi.Under Telephony service,
Hi.
Under Telephony service, which parameter for "max-conference and max-sessions" did you defined?
Let us know
Carlo
#show telephony-serviceCONFIG
i restart ip phone conference station and its worked!
Thanks for help all!
VIP Gold
Good to know that :-) Suresh
Suresh
80
