cisco 7940 and ethernet-over-mains adaptors
I'm currently trying to set up a phone system in a very big house that uses ethernet-over-mains devices to spread the LAN. Problem is everything works ok on this lan except the cisco 7940 ip phones I'm using. The phones are flashed with sip vP003-8-12-00 and they work fine on normal cat5 cables when connected directly to the router but when connected to the network-over-mains-adaptors the display shows 'ethernet disconnected'. I'm using standard patch cables and the mains devices are the 80mb/sec variety. Is there a special setting I need to use on the phones to overcome this problem?
Green
There was a field issue with this a few years ago (2003)
http://www.cisco.com/warp/public/770/fn27255.pdf
Cisco really wanted the failed phones sent back to them.
I assume we are over this.
I would test the connection by using a laptop for example at the
end of the cabling where the phone is being fitted.
It does sound like a cabling issue.
I'm not sure if you need a straight or a cross between the MAINS/ETHERNETS boxes and the
router or phone
Alex
Regards, Alex. Please rate useful posts.
thanks for your response alex.
I'll be back at the house over the weekend so I'll check the serial numbers then and see what my luck is like. I tested a 7940 at a different property using an 80mb/sec adaptor and it worked fine. I suppose I'll have to go right back to basics and work up from there, check the lan with a laptop first and see where the problem lies.
Hi Tony,
you can also check if the fuse of the power socket is on.
Are the two mains-adaptors on the same phase circuit?
Digging from layer -1
Sven
604
