02-20-2007 09:52 PM - edited 03-14-2019 08:08 PM
Is the newest SIP firmware for the 7940G XML based like the 79x1G series phones?
02-20-2007 11:54 PM
You mean Java based?
No, it's not.
XML instead is in all the models.
Remember to rate useful posts.
02-21-2007 12:03 AM
Sorry, I should rephrase. I ment to ask if the configuration files on the 7940 and 7960 phones were XML based like the 79x1 and 7970.
02-21-2007 01:23 AM
Yes, as I said all all the cisco phones uses XML both for configuration and display/applications, with the exception of 7902/06/12 that uses a different format of configuration files.
02-21-2007 01:25 AM
The last SIP firmware version I had on a 7940 was 8-4-0 and the config file was not XML based - I was wondering... Also, do you know if the 7940G supports symmetrical NAT?
