Cisco 7940G
Is the newest SIP firmware for the 7940G XML based like the 79x1G series phones?
Hall of Fame Super Gold
Re: Cisco 7940G
You mean Java based?
No, it's not.
XML instead is in all the models.
Remember to rate useful posts.
Re: Cisco 7940G
Sorry, I should rephrase. I ment to ask if the configuration files on the 7940 and 7960 phones were XML based like the 79x1 and 7970.
Re: Cisco 7940G
Yes, as I said all all the cisco phones uses XML both for configuration and display/applications, with the exception of 7902/06/12 that uses a different format of configuration files.
Re: Cisco 7940G
The last SIP firmware version I had on a 7940 was 8-4-0 and the config file was not XML based - I was wondering... Also, do you know if the 7940G supports symmetrical NAT?
130
