Cisco 7941 can't dial
Since yesterday, we have a phone that can no longer call. The phone find his configuration (number, location, calling search space ... etc. ...), can receive calls (Internal and external) but but when I want to dial a number, I hear numbers and then nothing, no tonality.
I try to reset the phone, shutdown phone, erase and recreate the line, Release DHCP address on the phone.
An idea ?
P.S. I've call manager 4.2(3)
Re: Cisco 7941 can't dial
I'd check the CSS that you have under the line and device in first place if the issue is only with outbound calls
HTH.
java
if this helps, please rate
www.cisco.com/go/pdi
Your phone appears to be bad. Try adding that directory number to another phone and see if you can dial out on that. Make sure the phone you swap it to is in the same partition as the bad one.
You may be having the same problem I am with the 7941 phone, a failure with the handset. Can you make calls with the speaker on?
Please post the CCM detailed trace including the calling party number, called party number and time of the call.
Is the problem happening when calling both PSTN and internal numbers?
It's the phone that was a problem. Our provider Orange/France Telecom change phone and it's ok.
Before to change, I try the phone number on an other phone and it's always the same.
lus
Hello, do you have a dialplan from france? Thanks
Hall of Fame Super Gold
Please stop posting duplicates, asking once is enough.
lus
sorry, will start a new one.
457
