Cisco 7960 cutting off
Hi, I hace a CME and a Cisco 7960 at reception. The phone keeps on cutting of and I wonder what the problem is. I changed the cabling and switch ports but still the same. the amazing part is that the call cuts only on incomming calls and works well with outgoing calls. When I run some connectivity tests, this is what I get
Target IP address: 172.16.99.121
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 172.16.99.121, timeout is 2 seconds:
Success rate is 85 percent (85/100), round-trip min/avg/max = 1/2/4 ms
I_to_I_Tech_CCME#tarc
I_to_I_Tech_CCME#trac
I_to_I_Tech_CCME#traceroute 172.16.99.121
Tracing the route to 172.16.99.121
1 172.16.99.121 8 msec * 0 msec
1 REPLY
Hall of Fame Super Gold
Re: Cisco 7960 cutting off
Hi, by design the ip phone doesn't respond to all pings.
Now for the calls "cut off", which FW do you have on the phone, and which exact IOS ?
The recommended FW is 7.2.T23 that is found exclusively within the zipfile called "CCME phoneloads" from CCO download.
279
