Cisco 7960 with VoipBuster
Hi All,
I've changed my Cisco 7960 firmware to SIP. Also I've configured my phone to call with VoipBuster, but it don't work.
When I turn on my phone, the settings will be downloaded from my TFTP-server. When I go to my SIP configuraton, I see the right Proxy, port, username and password, but in my main screen I see in the top (corner) "VOIPBUSTER SIP" with a phone icon. But in that phone icon, there is a "X". When I try to dial a phone number, the phone say:
To: 0031600000000 (Phone number)
Calling (out INV)
After 180 seconds (i think) the phone says: Reorder.
What do I wrong?
Firmware: P0S3-08-2-00
SIP Configuration:
Shortname: UNPROVISIONED
Authentication Name: XXXX
Authentication Password: XXXX
Display Name: VoipBuster
Proxy Address: sip.voipbuster.com
Proxy Port: 5060
Danido.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco 7960 with VoipBuster
Ok, in phone config file you may have:
try to set 1 and your public address respectively.
Hi Danido,
Is the phone behind NAT?
Can you take an ethereal trace to see what is going on?
Yes, my phone is behind a NAT.
Now I forward this ports to my Phone:
Any 8585 - 8585
Any 5060 - 5070
Any 16384 - 16484
UDP 123 - 123
UDP 69 - 69
But it don't work.
The Show Reg command (with telnet) show's the following:
1 .1x REGISTERING 3600 31 sip.voipbuster.com:5060
Note: APR is Authenticated, Provisioned, Registerd
I've already searched the forums, but I can't find the solution.
Danido
1176
